help with dropping the g and adding spacers
Old Aug 15, 2010 | 06:57 PM
luisp88's Avatar
Red face help with dropping the g and adding spacers
I'm planning on buying tein h springs which will lower my car f 0.6in and r 0.3in
I'll do the rear spring mount mod to even it out
my question is what spacers should i get after the drop?
i have the 350z anniversary 18" wheels
should i do 30mm(rear) and 25mm(front) any fender rolling if i do that?
or 25mm all around?
Old Aug 16, 2010 | 05:17 AM
Footballmania32's Avatar
What are the offsets on those wheels? I'm assuming 30+/33+. I am running OEM 19's on 20mm/25mm front/rear. Soon I'll be lowering my car on S-techs and I will 100% need to roll my fenders. So I would recommend rolling your fenders before you drop your car. And 20mm/25mm combo gives the car a great look. If your offsets are 30/33 like mine, it gives the car an aggressive stance. One more thing, be sure to purchase camber arms. Before I put on my spacers, was running about -1.7 in the rear. After the spacers I was at -1.9. So they do add a few tenths more of negative camber. Good luck!
-Sean
Old Aug 16, 2010 | 03:15 PM
Tyoung's Avatar
im lowered on 350z stechs with 25f/30r spacers and you only need to roll the rears...just figured youd like to know
Old Aug 16, 2010 | 03:28 PM
LightsOut's Avatar
SIETESG
go lower than H techs.
Old Aug 16, 2010 | 04:49 PM
Silencer_0's Avatar
^+1. You'll barely notice the drop.
Old Aug 16, 2010 | 05:07 PM
gary c's Avatar
You can run the Tein 350Z H-Techs which will lower your G slightly more than
the G35 H-Techs. I believe the difference is about 1/2" but regardless of how much you lower your G35 you'll NEED a camber it front/rear to bring your suspension back to OE specs....tires aren't cheap!
Gary
Old Aug 16, 2010 | 07:43 PM
plainomega88's Avatar
Id also say go with the 350z tien h-tech, plus rear springmount mod. Then at the least get a rear camber kit. 25mm in the front and 30mm in the back is perfect imo, but you will need your rear fenders rolled. You may not need em rolled if you dont do the rear springmount mod but not 100% sure on that.
Old Aug 17, 2010 | 04:59 AM
INDPNDT G's Avatar
I'm running stock 10 spoke g35 coupe 19's ... I'm looking to do spacers and Tein S Tech springs. Any suggestions on the spacers for this setup? Should I go with G coupe S-Techs or 350z s-techs? I'm thinking 25mm front, 30mm rear spacers. Please let me know... Also - anyone with pics of a similar setup would be great!!
Old Aug 17, 2010 | 10:37 AM
Tyoung's Avatar
i have that exact set up...stock 19's, 350z s techs and 25f/30r spacers...its the ****...i definately recommend it
Old Aug 17, 2010 | 02:04 PM
INDPNDT G's Avatar
Nice, you have pics? You have the stock bumpers, lip and sides?
Old Aug 17, 2010 | 02:37 PM
G3V's Avatar
G3V
if youre gonna spend that money you might as well go lower then G35 htechs
Old Aug 17, 2010 | 09:43 PM
walshtj's Avatar
+1 I would recommend the s-techs, not too much of a drop but looks great!
Old Aug 17, 2010 | 11:06 PM
the_sedan's Avatar
tanabe springs ftw
Old Aug 17, 2010 | 11:11 PM
luisp88's Avatar
this is what im aiming for with my car
http://www.myg35mods.com/tutorials/springs/index.html
i dont want it too low
i know its not much of a drop
but it works for me would i need fenders rolled
and 30mm 25mm rear/front would work
keep in mind i have 18" 350z anniversary wheels
thanks
Old Aug 17, 2010 | 11:25 PM
INDPNDT G's Avatar
How much lower will the 350z s-techs be then the G35 s-techs?
The G35 s-techs show a greater drop then the 350z's???
