Ignition/Key Light Ring and Position
Old Sep 3, 2010 | 01:07 PM
switchlanez's Avatar
This is nothing major, just curious. There's a translucent plastic ring around my ignition key hole. Does the top of that ring normally stick out of or sit flush with the surrounding black plastics? Does the bottom of that ring sit sunken into the plastics? And is there supposed to be a little split in the ring in the top part? (See pic.)
Also, when your key is in the 'ON' position is the head almost perfectly horizontal or parallel to the ground? (Again, see 'ON' position in pic.) In other cars I'm used to it being vertical in the 'ON' position o_O
Old Sep 3, 2010 | 08:22 PM
Jg35skyline's Avatar
That's a easy replace just pull out.....
Old Sep 3, 2010 | 08:39 PM
^I know but is what you see in the picture normal? Why waste my time if it's already the way it's supposed to be?
Old Sep 4, 2010 | 01:16 AM
Could someone check this in your car? Should be easy and quick
Old May 28, 2013 | 08:05 PM
Drakesapphire's Avatar
Does anyone know the light bulb type and size of it?
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
mtlruss
Dec 20, 2015 01:51 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Jadenkid22
Jul 14, 2015 12:33 AM
