Engine Failure (again) Need Advice
Old Oct 14, 2004 | 10:42 PM
beneteau1's Avatar
Re: Engine Failure (again) Need Advice
My engine has also failed. The dealership origninally blamed it on my driving habits. It was later determined that the car burned over a quart in the first thousand miles of driving after an oil change. A compression test and leak down test were done. The dealership determined that there was a failure on the left side of the engine but did not specify what that failure was. Infiniti wants to replace the long block -basically the entire engine. I'm not satisfied with this. BTW, as far as I can tell my tail pipe isn't smoking either.
Assuming you haven't done anything to the car that may have caused the problem, DEMAND that a leak down and compression test be done. As far as I understand it, that's the only way to know for certian whether there is a problem with the short block. Moss-Magnision puts the burden on the Nissan to demonstrate that you've done something to cause the problem. They can't do that without undertaking reasonable tests.
Go to lemonlaw.com. Its a law firm that handles lemon law cases exclusively. It may be able to help depending on what state you are in. You are definately not alone in this.
Old Oct 16, 2004 | 01:02 AM
skeleton_cru's Avatar
Sedan
tonio, you are not alone. I had engine failure on my sedan 6 weeks ago due to excessive oil consumption. Check out my thread:
https://g35driver.com/forums/showfla...sed&sb=5&part=
There is a ton of info in that thread to arm yourself with when you are dealing with the service people/consumer affairs.
The bottom line is the dealership MUST prove that your mods caused the engine failure. They will not be able to do this. Stand your ground and DO NOT give in. After three weeks of BS, they finally agreed to repair my G under warranty. I am having my long block replaced as I write this.
Email me if you need any advice skeletoncru@sbcglobal.net
Old Oct 16, 2004 | 02:08 AM
Silver03G35's Avatar
does the technosquare reflash void the warranty????
Old Oct 16, 2004 | 02:16 AM
JusG35c's Avatar
Check some of the z forums I believe when the z came out & even now some cars had this problem.
Old Oct 16, 2004 | 06:41 AM
Sedan
If they can prove the technosquare caused the problem, yes.
Old Oct 16, 2004 | 12:36 PM
GforceI's Avatar
G SQUAD
Oh man I just spend nearly an hour reading that whole thread. I hope that I dont have a quarter of the problems that you had SC with the repair but it's good to hear that you got it taken care of. Def a good thread for anyone that thinks that they may have to deal with these issues and thank god for G35driver cause I wouldn't be able to fight a battle like that one alone most likely.
Old Oct 16, 2004 | 06:05 PM
tonio's Avatar
Pretty interesting update.. I took the car to another dealership and they changed the oil and marked everything dealing with the oil I assume? I'm told nothing can be touched and to bring it back in at 3000 miles.
Because I know I wont make 3000 miles without adding oil I asked if I can add oil. The answer was basically it doesn't matter if the engine locks up before bringing it back in, just do not touch anything. So here we go..
magnetism80
Feb 1, 2019 10:00 AM
Jnm07
Sep 5, 2015 01:16 AM
crakke
Sep 1, 2015 04:23 PM
pigpen infiniti
Aug 16, 2015 09:07 PM
