tried to do the seat heated switch mod
Old Sep 23, 2010 | 08:23 PM
the evil i's Avatar
and i broke the switch lol
how much is the dealer going to charge me for new switches. now that i saw the inside of the switch, im not going to even bother to put in the led's. looks way to complicated. anybody have a quote on dealer installing two new switches?
Old Sep 23, 2010 | 09:07 PM
the04coupe's Avatar
its pretty hard to break the switch . Its just a white piece inside that slides back and forth .Wiring the leds in them is a little hard since it has almost no room .You have to cut one leg off the led and solder up a resistor to it so one leg of led is on one pin and resitor on the other pin.
Heres a pic of mine.Not the best quality though but it may help with fixing it .
Old Sep 23, 2010 | 09:09 PM
DT35G's Avatar
What is this mod???
Old Sep 23, 2010 | 09:11 PM
the evil i's Avatar
no i mean like the top part is broken, the part that actually lights up. i pried it off too hard and now when its on there it just wiggles, doesnt stay firm
Old Sep 23, 2010 | 09:12 PM
the evil i's Avatar
Originally Posted by DT35G
What is this mod???
https://g35driver.com/forums/interio...-mod-pics.html
Old Sep 23, 2010 | 10:03 PM
the04coupe's Avatar
i see what you me . Your suppose to take it of from the bottom not the switch part . You stick a small screw driver and pop the bottom out and the whole cover with switch slides off . Problem is the link shows it wrong . the switch is not supposed to be taken off of the cover . Dont know why he did that at all
Old Sep 23, 2010 | 11:13 PM
the evil i's Avatar
stick a small screwdriver where? do i have to take off the entire console?
Old Sep 23, 2010 | 11:22 PM
the04coupe's Avatar
The conole just pulls up and switch slides out the bottom .Takes litterally 1 min to get them out .
Pull down shifter trim on the shifter remove cotter pin then just lift the shifter off (10sec.)
Open armrest and lift main console piece (comes right up) .(2 sec.
Switches are just force fit .Pull tab and slide switch out the bottom(10sec.)
Unclip wire harness (10sec)
To open you will see a tiny opening on each side of the bottom of the switch housing. Insert flat head there and pop the cover up and slide off
Old Sep 23, 2010 | 11:24 PM
DG_coupe's Avatar
which side do you need? I have a extra one laying around if you need it. PM if your interested
Old Sep 24, 2010 | 01:51 AM
TrixR4kidz's Avatar
Omg clean your nails bro!
Old Sep 24, 2010 | 01:56 AM
the04coupe's Avatar
lol knew that was comin . Was doin bodywork and took a break to take those pics for someone .
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
linedr89
Aug 17, 2015 05:11 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
vstypicals
Jul 20, 2015 10:55 PM
