.:BLOWN PISTON..REV-UP or NON REV-UP ?:.
Old Sep 28, 2010 | 10:50 AM
t2dato's Avatar
Cool .:BLOWN PISTON..REV-UP or NON REV-UP ?:.
So i blew a piston str8 thru the engine and its done for..i was looking around and im not sure wether to Rplc my engine with a Rev-up motor or non rev-up motor..the engine that i did have in it was a 04 non rev-up and definately had an oil consumption issue so i just wanted some opinions and advice..Thanks in advance
Old Sep 28, 2010 | 11:24 AM
Canadian's Avatar
Canada, eh?
If you get a rev up you will need a new ecu and some sensors. Just get a non rev up.
Old Sep 28, 2010 | 12:07 PM
gary c's Avatar
Unususal to have OC issues with a non-rev motor. Replacing it with a rev-up motor would only cause you further issues. Non Rev-up would be your best bet since your history isn't great! Do you ever change your oil....?
Gary
Old Sep 28, 2010 | 12:43 PM
t2dato's Avatar
thanks and yes i change it every 3000 miles with royal purple. i guess it was just time for it to go bye bye
Old Sep 28, 2010 | 12:46 PM
partyman66's Avatar
Royal Purple FTL. I hate that stuff.
How many miles did you have on your car?
Old Sep 28, 2010 | 12:54 PM
thescreensavers's Avatar
Mr.202?
did you ever check the oil level?
Old Sep 28, 2010 | 12:55 PM
Hotdawwgman's Avatar
are you the original owner, how hard do you drive your car? Are you always taking it to the redline? Some info isnt being told here!
Old Sep 28, 2010 | 12:57 PM
LightsOut's Avatar
SIETESG
forget DE, or DE revup go HR
since you're thinking about revup anyways. the hassle of going revup will be the same as going HR.
Old Sep 28, 2010 | 01:02 PM
:facepalm:
Old Sep 28, 2010 | 01:30 PM
herrschaft's Avatar
The HR motor would be nice but it would be much easier to replace with a non rev-up.
I too want to know what caused the engine to blow.
Old Sep 28, 2010 | 01:47 PM
t2dato's Avatar
I am the second owner i bought it when it had 56,000 miles it now has 76,000 and iv'e had it for about a year and a half now mostly highway miles i was in the military and used to travel alot but now im out and i've been pretty good with changing the oil every 3,000 miles.. i do drive it pretty rough but never red line it i always just haul *** on the highway up to about 5k rpm when i do and never drift it or anything so not sure if maybe the previous owner abused it..i had the clutch and flywheel replaced at 66,000 i think im going to go with a non rev up and use a different synthetic oil
Old Sep 28, 2010 | 01:50 PM
viceversa's Avatar
Old Sep 28, 2010 | 08:56 PM
walshtj's Avatar
sucks but def non revup
Old Sep 28, 2010 | 11:45 PM
t2dato's Avatar
thanks a lot guys i have decided on non rev up should be running again by the end of next week
Old Sep 29, 2010 | 12:53 PM
3rick35c's Avatar
Under Construction
damn sorry to hear this happen to another driver... i just recovered from a blown motor myself... 2k later its up and running again...and not having a car sucks
