How do I program the Keyless Entry?
Old Oct 17, 2004 | 05:34 PM
sinthetiq's Avatar
I want to make it so the doors lock when I start the engine. It is a 2004 G35C. Any help will be great!
Thanks!
Old Oct 17, 2004 | 06:19 PM
sinthetiq's Avatar
Re: How do I program the Keyless Entry?
apparently none of the nissans/infinitis
off this feature!?
Old Oct 17, 2004 | 07:14 PM
dave's Avatar
The car does NOT have that feature built in.
Kpierson has made a product that will lock the doors a few seconds after you turn the ignition on. It works pretty well. Check out KPTechnologies. The product is the "Wondow Roll-up".
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Oct 17, 2004 | 07:56 PM
djrobx's Avatar
No car on Earth locks its doors when you turn the car on.
<hr></blockquote>I assume you mean no stock car ... Lots of aftermarket alarm systems lock the dors as soon as the ingition is started.
-- Rob
Old Oct 17, 2004 | 08:06 PM
roadracer's Avatar
I have a friend that works at Tustin Infiniti and I have an appointment next week to have that feature added (auto door locks that is)? He says it is programmed throught the ECU and that only the dealer can do it, but it is free of charge! Not sure exactly how this works on the Infiniti, but he says it locks automatically at a certain speed and if like my Bimmer that is around 15MPH.
'03 G Coupe, 6 speed, Bose, Nav, Ivory Pearl / Graphite, 350Z airbox, more MODS to come!
Old Oct 18, 2004 | 01:03 AM
bdtzmaru's Avatar
Let us know how the programming goes. If successfull, I will make an appointment to have this done too. I bought my car from Infiniti Tustin and was planning to make an appointment to fix my tint. Might as well add that feature too!
Old Oct 18, 2004 | 02:04 AM
KPierson's Avatar
There are stock cars that do lock the doors as soon as you start them, it was either a chevy or a ford, but I can't remember. I didn't believe it myself until I saw it. Most cars are set to lock between 5 - 15 mph. The Infiniti can NOT be programmed to auto lock. Unless they just happened to leave that feature out of the owners manual, the electronic service manual, and out of the hands of most dealers.
There are several fixes to this issue. The quickest and somewhat easiest way would be to wire a relay to the starter wire so that everytime the starter engages the doors lock. However, in the G, the only easy way to get the doors to lock is to do a 5 wire door lock interface. Since you only care about lock you don't need two relays.
Another way is the KPtechnologies module. We think our next module is going to be a speed controlled door locking module, but there is no guarentee on that.
A third way would be to use a pulse timer inside the door panel. You could hook it to the RAP wire and have it send a door lock pulse every time you start the car to lock the doors. Inside the door you can lock the doors with a simple ground pulse, no relay needed.
If you have any questions feel free to let me know.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Oct 20, 2004 | 02:02 PM
roadracer's Avatar
Well, I dropped off my car this morning and told the service manager I wanted the auto lock feature enabled (among other things) and he said no problem? Granted, I do not have the car yet, but either he has no idea what that is, or he know exactly what it is and will program it? I will post the results after I pick up the car this afternoon?
Old Oct 20, 2004 | 02:20 PM
G35scBkNy04's Avatar
G SQUAD
kp....in all Lincolns the doors lock upon starting the car
Old Oct 23, 2004 | 04:17 PM
KPierson's Avatar
I seriously doubt the new ones do too. I'm sure they only did it for a year or two, because it is a retarded feature. Speed controlled is the best way to do it, hands down.
Kevin
AIM: KPiersonTec
Old Oct 23, 2004 | 05:02 PM
rdr118's Avatar
I had a Pontiac Bonneville (2000) where the doors locked when you put it in gear and unlocked when you put in park.
Old Nov 21, 2004 | 07:34 PM
roadracer's Avatar
You were right Bro! The auto lock feature is not available on G's? Glad you know your stuff, but it makes you wonder how your title could be Infiniti "Service Manager" and you know more than him? Oh well!
'03.5 G Coupe, 6 speed, Bose, Nav, Ivory Pearl / Graphite, 350Z airbox, more MODS to come!
