Went to the dealer and they said my SES is on because of my Cats. plz help
Old Nov 10, 2010 | 05:43 PM
jebus2006G35's Avatar
i have 300 cell High Flow cats. i never had problems with the light being on before. i have tried Reset. The ECU but no help. Im going to try to get the code today, but im wondering if i need to replace the sensors. my warranty ended last month so they cant help. i search but found nothing. any help is welcome. thanks guys.
so i went back and they gave me the code. Its PO420- CATALYST EFFICIENCY BELOW THRESHOLD (BLANK 1).... what is that? do i have 2 remove them. i dont want it 2 affect my performance. thanks
Old Nov 10, 2010 | 06:05 PM
Project's Avatar
Post the code go from there.
Could be anything from the sensors are garbed up, to they could have been burned up.
Old Nov 10, 2010 | 08:21 PM
cool bro. im going back 2 the dealer 2 pick up car. ill get the code
Old Nov 10, 2010 | 08:54 PM
ballisticus's Avatar
Do the ECU reset method here http://www.technosquareinc.com/350reset.htm and then do the spark plug "non-fouler" trick.
First, you need to buy TWO pairs of the non-foulers at the local auto parts store. One pair needs the small hole to be drilled out with a 1/2" drill bit or whatever will allow the O2 sensor tip to clear it. Once one set is drilled out, you take a drilled non-fouler and screw it onto the O2 sensor. Then take the NON-drilled one and screw it onto the DRILLED one. So the order goes, O2 sensor-->Drilled-->Non-drilled-->cat.
The goal here is to take the O2 sensor out of the direct exhaust stream and isolate it somewhat. I had this setup with my test pipes for 2 years and never had a SES light once.
Old Nov 11, 2010 | 12:26 AM
crazy stuff bro. is there pics or a DIY on how 2 do it. thanks for ur help
Old Nov 11, 2010 | 01:19 AM
herrschaft's Avatar
In for DIY
Old Nov 11, 2010 | 07:38 AM
adamls2's Avatar
I just installed my test pipes 2 and the ses light came on after 10 min of driving... So im understanding that the dealer cant do anything about this and that the easiest way to get rid of it is an ecu reset?? :/
Old Nov 11, 2010 | 08:51 AM
M302_Imola's Avatar
you will have to use the O2 defouler method discussed above. W/ test pipes you have no cats so the car will throw cat efficency codes like the OP (his codes are probably from the HFC's not heating up to the appropriate temp.). So you will either have to do the defouler method or O2 sims.
Old Nov 11, 2010 | 10:28 AM
flyinb501's Avatar
Originally Posted by herrschaft
in for diy
+1.
Old Nov 11, 2010 | 10:35 AM
SDGenius's Avatar
OP, i'm pretty sure it's not ur cats. prob just a bad O2 sensor, go to any autoshop and have them switch them out and clear the code.
Old Nov 11, 2010 | 10:40 AM
Here is a picture of what they look like installed.
https://g35driver.com/forums/archive...on-fouler.html
You just buy 2 pairs of non-foulers at any Auto parts store. Thread an undrilled one (small hole on the end) into the cat. Then take the other one and drill out the small hole with a 1/2" bit or whatever will allow the O2 sensor tip to clear the hole. After it is drilled, thread it into the one already in the cat. Now thread the O2 sensor into the end of the drilled one. Done.
Remember, this is only to be done on the O2 sensors in the cat (closest to the rear of the car). DO NOT do this on the ones closest to the engine or it will totally screw up your fuel/air mix.
Old Nov 11, 2010 | 01:09 PM
thanks lot for ur help guys
Old Nov 11, 2010 | 01:16 PM
Thumbs up
cool bro. thanks.
Old Nov 11, 2010 | 01:26 PM
found this DIY.
Old Nov 11, 2010 | 02:51 PM
i see that there long and short non-foulers. does it matter?
