Is there a way to reverse the traction control button?
Old Nov 11, 2010 | 08:21 AM
breezerboat's Avatar
The first thing I have to do every time I get in my car is hit the VDC button. is there a way to reverse it so that I hit it when I want it on?
Old Nov 11, 2010 | 08:26 AM
Project's Avatar
Yes. Search for KP modules. They make a package that disables it until you click it back on. Around 50 bux if im not mistaken.
Old Nov 11, 2010 | 08:29 AM
Project's Avatar
Im bored so here you go.
http://www.kptechnologies.com/products.php#/4
Old Nov 11, 2010 | 09:14 AM
Thanks. I was hoping there was a way to do it without buying a part. So, there is not an easy, quick, free method?
Old Nov 11, 2010 | 10:01 AM
herrschaft's Avatar
^Just start cutting random wires.....thats free and simple
Old Nov 11, 2010 | 10:06 AM
OBsessed's Avatar
There was a thread kicking around sometime back that had info about disabling traction control, I remember reading something about a sensor under the center console that you had to unplug or bypass to fully disable VDC. Don't recall if it helped with the switch but might try searching for that (try either DIY or Drivetrain section mabye, it's been a while).
Old Nov 11, 2010 | 10:19 AM
herrschaft's Avatar
Not sure if the VDC is the same on a Z:
http://my350z.com/forum/engine-drive...bling-vdc.html
Old Nov 11, 2010 | 10:20 AM
OBsessed's Avatar
Yay me, I found the link! It'll be cheaper and easier to buy the part from KPTechnologies, but here's the how-to link if you're bored...
https://g35driver.com/forums/60113-post8.html
Old Nov 11, 2010 | 08:53 PM
TripleHBK's Avatar
There is.. it's called continue hitting the button. Doesn't get any easier or cheaper then that.
Old Nov 11, 2010 | 09:24 PM
walshtj's Avatar
True but the whole point was he didn't want to do that every time getting into the car..
Old Nov 11, 2010 | 09:52 PM
Xet's Avatar
Xet
Then he has to pay for the KP or do the wiring work himself.
Old Nov 11, 2010 | 10:48 PM
SC23x's Avatar
Any reason you turn this off constantly?
Old Nov 12, 2010 | 06:14 AM
jdub850's Avatar
yeah good question
Old Nov 12, 2010 | 06:48 AM
RBull's Avatar
Rated M
^+1
Old Nov 12, 2010 | 08:01 AM
OBsessed's Avatar
If you have changed the gearing in the rear axle and really get on it with VDC enabled, it will be more likely to trigger the "no fun" mode.
If the outer diameter of your wheel/tire sizes have changed significantly from stock and you really get on it with VDC enabled, it will be more likely to trigger the "no fun" mode.
If you just like slipping the back end out or enjoy spinning tires...
If you think you're a better judge of your vehicle dynamics than the Bosch yaw control box under the console...
There are a few reasons, there's probably more out there but these are good enough for many. The KPTech relay coupled with the switch on the Bosch box is nice, would recommend it, but your driving style and desire will vary.
Personally, the only times I have VDC on are when my wife's in the car or the roads are slick from heavy rain or the very rare ice/snow that hits NC.
