Tried to hardwire radar detector and now my car won't drive!
Old Nov 18, 2010 | 08:55 AM
blazeplacid's Avatar
Originally Posted by WhosRich
Sometimes even if it looks like its fine, it could still be blown.
yup
check em with a multimeter
I dont like test lights to much, they work, but when its a big issue like this I like to use a meter
you can check for voltage and resistance
Old Nov 19, 2010 | 03:45 PM
PEARL-G's Avatar
if none of this works, disconnect the pos and negative of the battery and just let the car sit for at least 30 mins or more. let us know how its goin!
Old Nov 19, 2010 | 04:07 PM
DT35G's Avatar
Anytime i had trouble with a car going very slow like that it turned out to be the Mass Air Flow Sensor. Figure out a way to test that and make sure you didnt fry it somehow. Also, most of your MAJOR fuses are in the battery compartment. Thats where i would start. Also look where you tried to hard wire and make sure there is no bare wire touching any metal and see if there is any melted rubber or wire housing up there, then trace it and figure out where it leads to.
Old Nov 19, 2010 | 04:18 PM
PEARL-G's Avatar
my thoughts is that if the car drives, its not a fuse, odds are you may have sent a short signal to the computer and the car is in a "limp mode" this happened to me when i got rims and never programmed any of the tpms sensors. if the car simpky wouldnt do anything like starting, then id say it could be a fuse, idk jsut my 2c's. like i said, try to disconnect the battery comletely and let it sit for a while, this should reset the computer.
Old Nov 20, 2010 | 08:07 AM
Gee35init's Avatar
If your battery is dead you have a dead short, you grounded a wire somewhere for sure
Old Nov 21, 2010 | 11:08 AM
dave's Avatar
Did you get it fixed? What was the problem?
Old Nov 22, 2010 | 12:19 AM
breezerboat's Avatar
Yikes!!!! I bought my G from a good friend and he installed a mute button close to where the left hand sits when it's not on the steering wheel. Very convenient....especially when I have a passenger in my car . They don't ever even know I muted it.
Old May 5, 2011 | 03:42 PM
kvp35's Avatar
Its a fuse, this same thing happened to me in my 03 Z. My dad flipped out cuz we had just got it home that day lol. I checked all the fuses with a fuse tester and found one blown. Replaced it and everything came back online, I was careful to not touch the wires together at that point and completed the install perfectly.
Old May 5, 2011 | 03:48 PM
Thanks for the help 7 months later
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
newbdriver01
Jul 16, 2015 11:35 AM
