NEED HELP!! Cant remove stock air box!
Old Dec 3, 2010 | 04:46 PM
cHink's Avatar
I am trying to install my stillen intake.
I unscrew everything for the stock air box. from the strut bar, from the intake and did the unlock switch. it is loose right now and i cant figure how to take it off !!!!
i dont want to force it right off, what should i do?
i am doing this by myself and first time installing a mod, heard it was easy for other people first time installing an intake by there self so i might give it a try
Old Dec 3, 2010 | 04:52 PM
cHink's Avatar
EDIT: Is there something attach to the bottom of the airbox that i need to unscrew?
Also how do i remove the ECU?
Old Dec 3, 2010 | 05:05 PM
Deepdiver's Avatar
its a tight fit..just work with it and it come out. Why do you want to remove the ECU? Do you mean the MAF?
Old Dec 3, 2010 | 05:17 PM
cHink's Avatar
i am trying to remove the ECU chip looking thing so i can take it out and install the intake part. After that i can do a easy install on the Z-tube which would be easy
i already took off the airbox and yes it was a tight fit. took me a while to get it off
Old Dec 3, 2010 | 06:21 PM
gary c's Avatar
***** you do need help! When installing the z-tube/intake all you need to do is remove the negative side of the battery and put it back upon completion. *****, do not mess with the ECU....ever!
Gary
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
