Check engine light on
Old Dec 20, 2010 | 01:11 AM
tt88supraman's Avatar
I have an 05 g35 coupe with 54000 miles. I was driving earlier and my jerked and the check engine light, sip light and vdc off light came on. And my car shut off twice on my way home. What should I do? I think I'm still under powertrain warranty. Is this covered by powertrain? Has anyone had the same problem before?
Old Dec 20, 2010 | 01:24 PM
MHellmann's Avatar
Cam sensors
I would replace the two cam sensors located at the back of each head and the crank sensor at the center bottom of the engine just below the flywheel, about $ 70 each. Quick to change and known to fail.
Old Dec 20, 2010 | 03:18 PM
spoolinupblue's Avatar
if under warranty, take it to the dealer.
Heck...go to Autozone nad have the code pulled. Then we can help alot better
Old Dec 20, 2010 | 04:19 PM
How much does autozone charge for pulling the code?
Old Dec 20, 2010 | 05:23 PM
I just got the codes pulled. Its the cam sensors failure. Is that under powertrain?
Old Dec 20, 2010 | 06:08 PM
superchargedg's Avatar
What year and how many miles.
Old Dec 20, 2010 | 06:28 PM
05 with 54xxx miles
Old Dec 20, 2010 | 10:17 PM
You said your G is under warranty, you should find out if it covers that.
I bought both sensors and replaced them in an hour. Do a ECU reset afterwards.
Old Dec 20, 2010 | 10:50 PM
gary c's Avatar
If you still have a warranty the cam sensors w/b covered, they're not like brakes that are supposed to wear out....
Gary
Old Dec 21, 2010 | 01:29 PM
I meant to say my cars still under POWERTRAIN.
Old Dec 21, 2010 | 04:42 PM
Update! They said my crankshaft sensor failed. And That's not covered by powertrain?!? Also they said my cars electronic module needs to b updated. I'm guessing they r trying to charge me for that as well. *sigh*
Old Dec 21, 2010 | 05:51 PM
So... I just got off the phone with the stealership. $130 for diagnose, $219 for crank sensor, $137 for reflash. What should I do?!?
Old Dec 21, 2010 | 06:08 PM
Get it fixed since it is there but dont waist the money on the update.
Old Dec 21, 2010 | 06:32 PM
So... Don't get the update? And ya I'm just thinking about getting it fixed there since it's already there.
Old Dec 21, 2010 | 07:41 PM
gary c's Avatar
You're already into the STEALERSHIP for the buck thirty may as well have them fix everything. How is it that cam sensors aren't part of your engine aka powertrain warranty? It's a shame that we can't leave an Infiniti dealership with feeling we've been screwed....
Gary
