Clear Stone Guard on Rear Rocker Moulding
Old Oct 29, 2004 | 11:54 AM
vinny's Avatar
I have a question for anyone that has intentionally or by accident removed the clear plastic stone guard on the rear of your coupe. The lower piece on the rocker moulding, not the one on the rear quarter panel. If so was it a success? Or did paint come off when it was removed. Also if you did do this what did you use to remove it. A blower dryer, etc... The reason I am asking is that after almost two years without any body issues I hit something in the road that damaged it severely and took paint off the rocker moulding too! Any input / feedback on this would be greatly appreciated. Thanks.
Old Oct 29, 2004 | 12:23 PM
wizawuza's Avatar
Re: Clear Stone Guard on Rear Rocker Moulding
You mean the stuff that's like a clear bra kinda right?
If so, that's not painted, it's clear. To take it off will be a pain in the butt, but it shouldn't tear up the paint. Just be careful. I dunno what would make it easier to take it off, sorry.
2004 TB/W 6mtC. Sunroof only.
Bel Vector 985
Grounding Kit
Splash Guards
Custom Carputer
Custom FG Sub
Infinity KapPerf6.1, Ref 6002si, 5760 6-ch AMP.
30% Huper
Old Oct 29, 2004 | 12:34 PM
Burrcold's Avatar
does everyone have these stone guards on?? I just got my G and find that they stand out alot on the black paint. I want to remove them but I'm a little hesitant as well.
2004 Infiniti G35 Coupe 6MT
Old Oct 29, 2004 | 02:03 PM
Premier's Avatar
the film holds about 50lbs of pressure per sq. inch, so it will take some effort to pull off. I'm not sure when they applied this film, but if the film was put on the car right after it was painted, then yes, the paint will likely come off w/ it. If the paint did not get the sufficient amount of curing and drying time before anything covers it, then it will bond w/ the film once it dries up.
If you're going to try to remove it anyway, then just pull slowly and don't use a heat gun or blowdryer. Once you removed it successfully, you will likely have residue, which could be removed by 3M's Residue Remover. Good luck.
Certified Window Tint & Detailing Specialists
Certified Paintless Dent Repair Technicians
VentureShield Paint Protection Film Dealer
Madico Window Film Dealer
2003 AT Sedan / 2004 6MT Coupe
Old Oct 8, 2015 | 06:22 PM
ZacDecker's Avatar
I was able to peel and remove the guards by hand. Didn't need any heat. Used some Goo Gone for the left over residue.
Old Oct 12, 2015 | 08:49 PM
AuAltima3.5's Avatar
Let it sit in the sun for a bit. Pull it flat to the paint, like a 180* angle. Don't pull square to the paint.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
