Significant power loss. Where to start?
Old Jan 7, 2011 | 07:46 PM
mrtrodonet's Avatar
Hello everybody and thank you for your advices upfront.
I have 2005 G35 Coupe AT With 65k miles on it.
I use Mobile-1 oil and filters and change it every 5k.
Have changed my plugs on 60k (thought it may help, but gained 3hp only).
I was racing my friend recently. He has Subaru WRX 2009. i believe it has 245hp in it. Well i can understand that 4wd may be better on start but when i couldn't keep up with him on highway, i was pissed. (at last ihave +40hp )
I've used Dynolicious iPhone app to measure performance of my car. Here are the results after new oil change:
I've set up weight at 3700lb (Car+I). Drivetrain loss = 0.
0-10 0.88
0-20 1.86
0-30 2.91
0-40 4.04
0-50 5.39
0-60 6.83
0-90 13.91
1/4 mile 15.27 @ 94.6
Peak Horsepower 187hp - are you kidding me? WHERE IS ANOTHER 100HP!?
Check engine light is OFF.
Any thoughts?
Old Jan 7, 2011 | 08:00 PM
thatattguy's Avatar
Lemme guess, are you a colorado native like myself? Those numbers are exactly what i got just about for my 2005 5at coupe.
Altitude causes less air density = less of an explosion when spark hits the fuel.
so the rule of thumb is for every 1000FT ABOVE sea level you loss 3% HP. I live in Parker Colorado, so my altitude is 6080FT above sea level. 6*.3% = 18% HP loss.
Old Jan 7, 2011 | 08:31 PM
LMG_35C's Avatar
2009 WRX has 265HP and is about 400 lbs lighter. I drive a stock 2006 WRX (245HP) which I know is a bit faster to 60 than my modded G but begins to rapidly loose ground from 60-90+. IMHO a stock G would be no match. Even so, I think the G is superior in just about every other way.
Old Jan 7, 2011 | 09:08 PM
mrtrodonet's Avatar
Baltimore, MD. I live right on the ****** ocean ))
Old Jan 7, 2011 | 09:21 PM
Mark2K8's Avatar
Never knew about that dyno app...
do you need internet access for it to work
Old Jan 7, 2011 | 09:55 PM
mrtrodonet's Avatar
No, it is using a built in accelerometer. People say it is very accurate.
Old Jan 7, 2011 | 10:52 PM
Mark2K8's Avatar
Oh daymn. I downloaded it. Gotta check it out tomorrow.
Old Jan 7, 2011 | 11:52 PM
KevinHeld's Avatar
Is the WRX a manual trans?
Old Jan 7, 2011 | 11:54 PM
thescreensavers's Avatar
Mr.202?
The Dyno app is not extremely accurate. But its alright.
I would go to a 1/4mile track and get some official timing.
Old Jan 8, 2011 | 12:01 AM
mrtrodonet's Avatar
Yes it is. But it's not the point. I just don't get it. Where are my other ~100hp. Should i may be get one of those error codes testers and see if one of my sensors went bad or go to the shop to have it tested .... I know enough about cars on mechanical part of it, there is nothing that can be possibly wrong with it. It's a relevantly new car and has been taken a good care of.
What i don't know is may be there are some computer setting that should be rested or adjusted. If there are people who did chip tuning or who know how the electronic part of this car works, please set me to the right direction. Just don't wona go from shop to shop and pay $150 for diagnostic that most likely will have no result.
Old Jan 8, 2011 | 12:05 AM
Mr.202?
^ again your freaking out over an App, go get some official 1/4 mile times.
Old Jan 8, 2011 | 01:37 AM
luongdmd's Avatar
Did u miss shift?
Old Jan 8, 2011 | 01:41 AM
Project's Avatar
You just said it yourself. Theres probably nothing wrong with the car. If your worried a code is being thrown which would lead to a CEL light coming on then goto autozone or advanced auto and they do a OBD read for free.
Edit. Also your car is only rated at 280 at the engine. Even with mods your not over 300 i bet at the engine and then factor in age and altitude. I can imagine around 200 at the wheels which would be about right.
Old Jan 10, 2011 | 06:03 AM
andrewstclair's Avatar
yea just because the brochure says 280hp doesn't mean that actually what you have and it deffinatly doesn't mean thats what makes it to the wheels. the engine rated hp will NEVER come up the same number to the wheels unless your dyno is broken. you lose a significant amount through the transmission and differential and yours is an automatic which is even worse for losing hp.
you actually started a thread looking for advice bacause your iphone dyno app gave you a reading you didnt like???
Old Jan 10, 2011 | 06:06 AM
Eric@TCGMiami's Avatar
lol @ this thread.
