Engine noise please help.
Old Jan 31, 2011 | 08:05 PM
XternaL's Avatar
Hello, i'm new to this forum and wondering if i can get helped with my engine noise issue ( if it is engine noise to begin with ). Here is a video i recorded regarding the sound ( can hear the sound more clearly at the beggining of the video and 1:17 - 1:28)
Thanks for your help!
Old Jan 31, 2011 | 08:23 PM
Songle6MT's Avatar
It kind of sounds like a dry bearing noise really lightly.
However I assume you are talking about the "knocking" sound, is how I would describe it.
It is pretty faint noise, can you hear it while driving or how did you come across it?
Old Jan 31, 2011 | 08:26 PM
XternaL's Avatar
no i can't hear it while driving. I hear it during a startup kind of sound like a squeeking/bird chirping sound but i can't hear it from the inside of the car
Old Feb 1, 2011 | 03:34 PM
Songle6MT's Avatar
I personally wouldn't be too worried about it. It doesn't sound like it's anything catastrophic. I would just keep driving it and if it gets louder or something changes then look into it a little further. It could be a possibility of a thousand things
Old Feb 2, 2011 | 10:58 AM
pwestbball11's Avatar
It sounds like your a/c is on. Try turning that off and then see if that sound stops.
Old Feb 2, 2011 | 05:43 PM
XternaL's Avatar
my a/c was off the whole time i recorded the video
Old Feb 2, 2011 | 08:57 PM
Lucas's Avatar
either idler pulley or tensioner pulley bearing is going bad if its a "chirping" noise. kinda hard to tell through a video uploaded to the internet tho. if you have access to a vibration stethascpoe, you can diagnose pulley bearings with that.
Old Feb 3, 2011 | 10:47 AM
BW350GTskyline's Avatar
yea +1 to the post before about it could be numerous of things.. i wouldn't worry as well about it unless the problem worsens in any way
Old Feb 3, 2011 | 11:02 AM
gary c's Avatar
This is a tough call, doesn't sound like anything serious. Drive and enjoy your G, if it gets worse it will be easier to find....nothing serious since there's no clatter.
Gary
Old Feb 3, 2011 | 05:17 PM
XternaL's Avatar
thanks for the helped you guys i'll just enjoy it for now and see if anything happens in the future <3
Old Feb 3, 2011 | 05:25 PM
jibberjabbers's Avatar
Sounds like piston slap.
See this thread. Guy also has a video. Everyone blamed it on the ABS or said it was normal. It turned out to be a bad engine bearing. Metal shavings all over. etc etc. Engine was replaced under Warranty. He had a 5AT non Rev-Up.
https://g35driver.com/forums/engine-...upe-video.html
So, the only way to find out is to pull out the valve cover or oil pan and see if there are any metal shavings or damages. You're out of warranty so I'm guessing you're just going to wait it out and hope for the best. lol
Old Feb 3, 2011 | 07:44 PM
XternaL's Avatar
i highly doubt its a piston slap but thanks for the heads up
Old Feb 4, 2011 | 10:37 AM
TannerG's Avatar
Piston slap? That sounds dirty!
Let us know if you figure it out
Old Feb 4, 2011 | 06:42 PM
XternaL's Avatar
ok so problem solve. it was my tensioner pulley bearing going bad so i replaced it and everything sounds as it should be. Thanks everyone for your help!
rezendvous420
May 31, 2020 01:26 PM
Terry_G35
May 9, 2020 01:39 AM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
