PO335,po327 HELP!
Old Mar 5, 2011 | 01:15 PM
rwcblkcoupe's Avatar
PO335,po327 HELP!
So... Throwing a po335 crankshaft sensor and a po327 knock sensor.
Symtoms: stalls when warm at a light when at idle.
Will only turn over after turning over for abount 3-5 seconds. When cool starts right up. I know that there are two camshaft sensors.... is it best to just replace both?
I just pulled the crankshaft sensor under the car... a little metal shavings on the magnet part of it..... probably not good....but does that mean its bad? any help would be great!
Thanks in advance
Old Mar 5, 2011 | 05:58 PM
the_sedan's Avatar
change the crank sensor. as far as the knock sensor, shine a light down under the intake manifold on the block and you will see the knock sensor bolted down in there....make sure a rodent hasnt feasted on the wires....cuz ive seen that happen. but a knock sensor code isnt gonna give you an extended crank.
Regarder123
Aug 16, 2015 10:51 AM
