Please help!
Old Mar 25, 2011 | 10:51 PM
4D05G35's Avatar
Originally Posted by gowner
I understand that spacers make wheel go out but doesn't that mean that I can add bigger tires as there is extra space between wheel and any rubbing parts? Sorry but I never had spacers in my life but thought this is how they can be used.
P.S.
Those wire parts would not work for me as they would make car look a bit cheap in my opinion.
Yes you increase the space between the inner lip (back side) of the wheel and the suspension components, But you decrease the space between the outer wheel lip (face) and the fender. So while you gain clearance on one side, you lose it on the other.
Old Mar 25, 2011 | 11:25 PM
gowner's Avatar
Could I roll the fenders? I have never done it but I can try to find someone to do it locally.
Old Mar 25, 2011 | 11:27 PM
Xet's Avatar
Xet
P.S.
There is more room on the other side, but spacers don't make your wheel any wider. You can often size up a bit on the width of the tire, but if you do too much the tire ends up being designed for a rim much wider than yours is. That means the tire isn't being secured as it normally would, which could be dangerous. I would definitely doubt that you can safely increase the width of your tires enough to really protect your rims as well.
Best idea may be to try to teach your wife, and just wait for her to get her own car. Then you can just have your wheels refinished back to perfection. And you can always charge her each time it gets scratched up to help pay for that, or I'm sure you could figure something out
Old Mar 25, 2011 | 11:35 PM
gowner's Avatar
I guess my last question would be: What is the widest tire that could be fitted into my rims? I currently have 285/30/20 on back so I know this would be a good size but with spacers would this tire work up front?
