03 6mt Coupe with Transmission Problems
Old Mar 27, 2011 | 04:04 AM
ridemyjansen's Avatar
Hi everyone,
This is my first post on this site, came over from my350z.com. I know the issue has been beaten to death, and I've just about exhausted the search tool without finding a definitive answer. I just bought a used 03 g35 or v35 as we call them in Australia. The car has about 25k miles on it and everything is great except for the Transmission.
I first noticed the problem when going through a drive through and feathering the clutch in 1st gear. It sounded like there was a rotating steel can with nails bouncing around where the transmission was supposed to be. I tried giving it more revs and the grinding/rattling noise just got louder.
The same thing also happens in reverse and in 2nd gear at low rpms. After searching through threads here and on 6mt.com, There were mixed conclusions. Some have said it is normal, and some have said it was the clutch, Flywheel, Throw out bearing and every combination of the three.
I figured if i'd post with my unique symptoms it would generate a more accurate answer. I took the car back to the Dealership and they said they would "look at it".
Can anyone give me some suggestions to pass onto them to ensure that the problem is fixed correctly.
Thanks in Advance guys!
Old Mar 27, 2011 | 11:35 AM
strykez's Avatar
sounds like clutch chatter, do you know if the clutch or flywheel has been replaced or upgraded with an aftermarket one?
Old Mar 27, 2011 | 11:56 AM
Jaygotboost's Avatar
Id have to disagree with clutch chatter, noise should go away when clutch is engaged and resume when disengaged in most cases. Throwout bearing maybe, also hows the shifting and any slipage?
Old Mar 27, 2011 | 05:41 PM
G.Dogg's Avatar
I have a 03 G35 coupe Tansmission that runs good.., but the 2 to 3 gear sink row grinds when i power shift into it.. so i found me a CD009 or CD#2 transmission all my issues are gone i love this transmission.
Old Mar 27, 2011 | 05:45 PM
G.Dogg's Avatar
Change the tranny its the best solution
D.G 03 O.G Coupe 6MT/Brembo's/Nismo Bumper/Nismo Intake/Custom System Nav/TV/DVD/Rear view camera
Old Mar 27, 2011 | 05:49 PM
G.Dogg's Avatar
Btw it sounds like the engine has been changed on your ride do the same with the transmission
Old Mar 27, 2011 | 10:05 PM
Thanks for the input guys. As far as the car having an aftermarket clutch or flywheel, I have no idea. It was imported from Japan, as they aren't mass produced here. When the dealership calls, I'll be sure to ask.
I'll try to get them to cover the cost of a new transmission, it's not going to be easy though lol. It's a small dealership that specializes in imports and they have their own warranty plan
Where's the best place to buy a cd009 from? Any idea how much it would cost to ship it from the U.S. to Australia?
Old Mar 28, 2011 | 11:13 PM
G.Dogg's Avatar
i wouldn't advise that you buy the transmission from the U.S it will cost almost as much as the tranny to ship it there.. You should check out the japan market
Btw 03-05 G35 & 350Z are the same so if you find a 350Z 6speed cd009 pick it up it works thats what i have on mine
D.G 03 O.G Coupe 6MT/Brembo's/Nismo Bumper/Nismo Intake/Custom System Nav/TV/DVD/Rear view camera oh yeah & 05 350Z CD009 Transmission
Old Mar 30, 2011 | 05:27 AM
Ok guys, I an update! The dealer called today saying the problem was fixed. I Went to pick up the car and low and behold..the chatter and shudder are still extremely there. I blew up at the dealer, they had my car for 5 days and did nothing. I asked what exactly they'd been doing with it. He told me he ran a complete diagnostic, and he checked the whole tranny. When I asked if the tranny was even removed, to check the clutch, flywheel and bearings he said " why would I do that?"
Was I wrong to expect that the tranny would be taken off the car to do a full diagnostic? He told me the chatter was due to a "heavy duty clutch and dual mass flywheel". I wasn't buying the fact that the car had the stock flywheel and was still making this much noise at low rpms. He took me to the performance shop that did the trans. check and the owner pretty much told me the same thing, the only thing they did was put my car on the dyno and max it out to check for slippage, which apparently it didn't.
He also completely ruled out a new cd009 trans because he thinks there's absolutely nothing wrong with the car. Ugh..i'm on the ropes and I guess I have to bite the bullet and fork out the money for the tranny myself. Sucks to spend 23k on a car only to have it sound like cement mixer ever time it takes off from a stop.
Old Mar 30, 2011 | 09:23 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Your transmission is busted and needs to be replaced. It's not "clutch chatter", which is a shuddering under acceleration.
Old Mar 31, 2011 | 09:21 PM
strykez's Avatar
to rule out clutch chatter try going into first gear have the clutch pedal depressed and rev your engine to 1500 rpms engage the clutch slowly (release pedal) if you hear the clanging its clutch chatter. A dealership/repair shop wouldn't take apart your tranny and check out your clutch because it would take way to long and they would lose money doing it. Before you fork out any money for a tranny i sugest taking it to a tranny shop and getting them to diagnose it. Don't take it to the dealerships tranny shop.
Old Mar 31, 2011 | 10:01 PM
skyline250GT's Avatar
It wouldn't hurt to drop the transmission fluid and check it's condition - any metal shavings would suggest problems inside the transmission.
I've got an 03 350GT Coupe as well, trans has the usual 1st-2nd gear grind that most people have on here. These cars come from Japan with a lot of undocumented mods so it would be good to find out it's history.
Old Apr 3, 2011 | 05:49 AM
I made a video of the noise for you guys to analyze.
I'm going to be taking the car to a transmission specialist for a full independent diagnostic. If the dealer refuses to do anything after that point, I'll be reporting them to the department of fair trade( Australia's version of BBB).
Old Apr 3, 2011 | 11:19 PM
jicenroa's Avatar
that sounds like an aftermarket clutch and flywheel set up.
Old Apr 13, 2011 | 10:42 AM
powdajohn's Avatar
Sounds like an aftermarket used transmission needing repair to its synchros to me too.
NemesisGee
Aug 11, 2015 07:10 PM
multimut
Canada
Jul 26, 2015 08:43 PM
newg37
Jul 26, 2015 09:32 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
nervseele
Jul 17, 2015 11:21 PM
