Air leaking from tire stem?
Old Apr 5, 2011 | 04:23 PM
westbank23's Avatar
I have a slow leak and the air seems to be leaking from the tire stem.
Can I get this fixed at a regular tire shop or do I have to bring it to the dealer?I asked this because I heard that the stem is connected to the tire pressure sensor..true?
Old Apr 5, 2011 | 04:26 PM
Hi-TechG35's Avatar
Any tire shop with knowledge of the TPMS can fix this issue. Sounds like you have a bad seal around the stem or the stem may be bad itself.
Old Apr 5, 2011 | 04:36 PM
westbank23's Avatar
I'm thinking it might be a bad seal because it's not leaking from the top of tge steam(were u pump air at) but it's leaking from the bottom
Old Apr 5, 2011 | 04:52 PM
Hi-TechG35's Avatar
Okay. The TPMS basically just screws onto the valve stem so it shouldn't be a biggy. If you go to a Town Fair Tire they should be able to take care of it.
Old Apr 5, 2011 | 05:12 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
+1, any reputable tire shop can handle it. Call ahead, tell them the stem is leaking you don't know where and you have TMPS, and ask them to quote a stem replacement.
Old Apr 5, 2011 | 05:16 PM
BW350GTskyline's Avatar
i had a crack in the actual valve stem
Old Apr 5, 2011 | 05:20 PM
westbank23's Avatar
4sure
I'll bring it to the tire shop
Old Apr 5, 2011 | 05:21 PM
westbank23's Avatar
4sure
Old Apr 5, 2011 | 05:26 PM
gary c's Avatar
The Infiniti Stealership is the last place you want to go, if it's tire/wheel related always go to a reliable tire store in your area. If the sensor is bad and needs replacing check with a Nissan dealership, the cost will be considerably less!
Gary
Old Apr 5, 2011 | 07:04 PM
anynigma's Avatar
Gary
Thats a great tip. Might get TPMS for my winter wheels next year if these are affordable.
Old Apr 5, 2011 | 07:12 PM
westbank23's Avatar
Gary
You right and I should know better because I called tge infinti dealer to get some M/T gear oil and they told me it was $17 a quart then I called Nissan and they told me $11 quart for the same oil
Old Apr 5, 2011 | 09:48 PM
Cscat87's Avatar
I had air leaking from the valve stem, and it ended up being a crack in the metal stem itself of the TPMS, and the whole thing needed to be replaced. They can usually be found pretty cheap on the forums though.
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
derres
Aug 28, 2015 03:27 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
newg37
Jul 26, 2015 09:32 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
