wheel spacers
where are you ordering your spacers from??? i need to order front and rear also
Ps. Question i want 20mm front and 25mm rear but i have 20'' rim (will i have a problem people?????
(2007 G coupe sport)
You should be fine.
I was dropped on 350Z Tein H-Techs with 25mm all around with no rubbing.
Except when the car was loaded down with 2 friends and I'd go over dips on the freeway.
Here's some olds pics of my ride to give you an idea of the drop and look of the spacers.
btw this is perfect. I'll be following suit and doing 25's all around with that 350 H-Tech drop. thank you for the inspiration!
finally had enought time to get it all done! i went 25mm all around with 350z tein h techs for a drop. what do guys think? bought the car all most completey factory about 2 months ago and caught the mod bug pretty quickly. also changed the corner lights, shaved the g35 elmblem, tints, cross drilled rotors and hawk pads and stillen exhaust. any other suggestions? i want to keep it as clean as possible. was thinking of a lip possibly?
Ps don't buy eBay junk. Remember you get what you pay for!
