G35 bad clutch????? help!
Old Apr 11, 2011 | 06:19 AM
spacecitygroove's Avatar
Lastnight i was parked on an incline...
With the car OFF, i pushed in the clutch and put it in first gear.. my car began to roll back..
Should the car be rolling back if I have the clutch pushed in??? (the car is off)
Sorry if it sounds confusing..
Old Apr 11, 2011 | 08:33 AM
GrocryGettr's Avatar
You're parked on an incline in gear. The trans is keeping the car from rolling because the engine is off and will not turn over. Pushing the clutch in releases the trans from the engine and off you go.
That being said, I have a feeling the rest of the posts will be painful for you to read
Old Apr 11, 2011 | 09:07 AM
Hi-TechG35's Avatar
Old Apr 11, 2011 | 09:17 AM
_RR_'s Avatar
Lmao.....
Old Apr 11, 2011 | 09:29 AM
abcdo4dkIdjkm's Avatar
yes you car will roll backwards if you push the clutch in. And no its not bad. You should be using your e-brake as well.
Old Apr 11, 2011 | 10:00 AM
TannerG's Avatar
Is this your first car with a manual trans?
Old Apr 11, 2011 | 10:01 AM
well someone tell me why I cannot shift into any gear at all???
Im completely locked out of every single gear when I push the clutch in and the car is ON.
Is this a bad clutch or bad synchros?! this is killing me...
Cant drive that damn thing.. it sucks
Old Apr 11, 2011 | 10:24 AM
TannerG's Avatar
Is your car rolling backwards when you are trying to shift into a gear? You don't have a bad clutch. It sounds like user error. There's a thread on here about how to drive a manual. Check it out.
Old Apr 11, 2011 | 12:05 PM
izzueeek's Avatar
oh dear..
Old Apr 11, 2011 | 12:52 PM
_RR_'s Avatar
BAN THIS TROLL
Old Apr 11, 2011 | 02:08 PM
Jaygotboost's Avatar
Ok youre on level ground with the car on, you press the clutch and shift into first and release the clutch what happens? You need to be more descriptive if not get your SPF 5000 sun block ready :-)
Old Apr 11, 2011 | 02:16 PM
cmesidewayz's Avatar
hahahahahhaha priceless.
Old Apr 13, 2011 | 11:53 AM
TannerG's Avatar
Here's the thread I was talking about. Are you still having the problem? https://g35driver.com/forums/g-spot/...orrectly+drive
Joshua615
Aug 31, 2015 12:29 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
