Will these fit my G35?
Old Apr 18, 2011 | 10:10 PM
rico31286's Avatar
Hey guys, Im looking for new rims and and tires and need some info on fitment. I have an 03 g35 coupe with Brembos. I want a nice flush look. Here are the rims I found:
the size are 20x10 & 20x8
P.C.D: 5-4.5/5-4.75
offset : +35
Will these fit ?
What is the widest tire I can put on them?
I dont want the side walls thick but I also dont want to worry about every bump, so what would be good?
Will I need spacers?
are there any draw backs to using spacers? ( I do not want the performance of the car to suffer)
And any other info I might need or want, etc. Sorry for sounding so new, but any help will be wonderful. thank you
Old Apr 18, 2011 | 11:29 PM
cmesidewayz's Avatar
you might notice a little loss in low end power with 20's, unless you go with a super low profile tire
Old Apr 18, 2011 | 11:51 PM
walshtj's Avatar
You may want to search before actually purchasing. Your questions should only be answered by you, when your confident you understand the issue.. Yes they will fit if your on OEM suspension. They will be a little tucked with that offset(although it is pretty good). Use this website to maintain the same overall rolling radius(otherwise youll f up your Odometer/Tach/VDC...etc..) With 20" rims the mass is further away from the axle, thus it will take more force to maintain the same acceleration...i.e. "loss of power." Although its not an actual loss of power just 'feels" like it.. BTW are you coming from OEM 17s, 18s, or 19s?
http://www.miata.net/garage/tirecalc.html
Old Apr 18, 2011 | 11:52 PM
walshtj's Avatar
Double post...
Old Apr 18, 2011 | 11:54 PM
walshtj's Avatar
BTW comfort with 20s will be compromised, you will feel every bump and every pot hole.
Old Apr 19, 2011 | 12:16 AM
rico31286's Avatar
Thanks for the info. I currently have OEM 18s.
Old Apr 19, 2011 | 11:35 AM
rico31286's Avatar
I Think I am just going to get them. Now what is the widest tire I can put on those rims. I was thinking 285/30 and 245/30. Will this look aggressive? Is this enough wall so I dont have to worry all the time about small bumps and pot holes? Will this also raise my car?(I do not want it raised)
Old Apr 20, 2011 | 03:19 AM
geegeegee's Avatar
I'm pretty sure with those offsets, you won't be flush with your fenders. In a sense, you'll be higher.
Old Apr 20, 2011 | 03:33 AM
Affalterbach's Avatar
Dont do it with that +35 offset. Also you said the rear was 5x4.75, we have 5x4.5 all around or 5x114.3 iirc
Old Apr 20, 2011 | 05:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
You really need to do more research. A 285/30/20 will have a rubber band sidewall and will ride like ****. Good luck with that.
Old Apr 20, 2011 | 07:54 AM
Bump on right lug pattern. 5x114.3
If I'm not mistaken stock offset is +33 ? At least I think that's it for rays 19's. + 45 would be your best bet with staying flush
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
LoSt180
Jul 15, 2015 08:31 AM
