So I have had a horrible squeal under my hood for some time. First thought it was a belt, replaced those. Then I suspected a pulley, checked all and came to the power steering pulley. i took of the ps belt, and could tell there was a slight play in the mechanism of the power steering pump.
Anyone have this problem before?
Thanks all
Thanks all
did you figure out if the power steering pump was the cause? I noticed mine moves a little when there is no belt attached and think its the cause of some chirping i hear.
Mine turned out to be dirty pulleys. Removed belts cleaned pullies new belts on. Tighten belts.
