help: new tires and abs, slip, vdc off came on
Old Apr 27, 2011 | 09:16 PM
shoang86's Avatar
I replaced my rear tires (255/40/19 on 19 inch stock rims) and immediately after (about 3 miles) my abs, slip and vdc off light came on. abs would also kick in when i brake a little bit hard. I tried searching but nothing on people getting it after tire changes. could it be that they messed up some sort of sensor? i tried resetting the ecu. thanks guys!
Old Apr 28, 2011 | 03:05 AM
Affalterbach's Avatar
This worries me since I will be getting new wheels and tires soon.
Old Apr 28, 2011 | 04:28 AM
Condition's Avatar
^^^Same here, I'd love to hear an answer
Old Apr 28, 2011 | 06:22 AM
JustinG's Avatar
Don't know about the tires, but I experienced the same thing when my brake fluid was low. I topped it off and the lights disappeared.
Old Apr 28, 2011 | 04:44 PM
shoang86's Avatar
my guest is i need an alignment but i am not sure if that would trigger the abs light to go on. can someone confirm that its possible and i will take it this weekend to get it aligned. thanks!
Old Apr 29, 2011 | 12:50 AM
m3gtrfan's Avatar
Hey guys,
Couple of things. I got into a minor accident and replaced one of my 2 rear tires and rims....so I had a brand new tire and one that needs replacement. I've noticed not even 100km after I got my car back been getting all sorts of light issues. Tonight driving my VDC and slip light went on. my brake light went on but then went off. I'm freaking out. I'm changing rear tires tomorrow to both being matched up to see if that will correct the problem. willl post tomorrow.
Old Apr 29, 2011 | 01:03 AM
takeNotes's Avatar
In for the response to this. I just ordered my rim/tire set up as well and hoping this wont happen. I was at the shop today and was chatting up with the tech and he said if you dont reuse the same tire pressure sensor that you have on your stock oems, then those lights will come on. I dont know how true that is but apparently it is?
Old Apr 29, 2011 | 01:07 AM
alfhasg35's Avatar
That happened to me the first time I changed out my tires. Are they two different front than rears.. Something todo with the tread sensors or something. It took a while but after about 1000mi of my car driving like a car that felt like it was crashed, it went away. Dealer knew about it...
Old Apr 29, 2011 | 02:23 AM
Revo's Avatar
What size are your front?
With new tires it takes some time for the system to adjust but if you got sizes that were really far off factory size it'll screw things up.
Old Apr 30, 2011 | 03:32 PM
shoang86's Avatar
fronts: 235/35/19 (i was going to change these but the tire place said i still have a lot of meat left)
rears: 255/40/19 ( it was 275/30/19s before) (corrected size)
is it because my rear is higher than my front that will trigger the abs/vdc/slip?
Old Apr 30, 2011 | 06:19 PM
Blue Dream's Avatar
I drove ttrank's car solo
You need to keep the rolling diameter of your tires front and rear w/in 3% of each other to keep the VDC happy. Your front tires are 1.5" shorter than your new rears which is almost 6% different. You need to either get taller front tires or shorter rears.
I'm surprised you didn't have issues before as you still had a 4% difference at 1.1". Are you sure the old rears weren't 275/30? Those are exactly the same size as the 235/35 at 25.5" each.
Old Apr 30, 2011 | 10:27 PM
shoang86's Avatar
you are right, my old ones were 275/30. they were too thin for my taste so i decided to go thicker.
so getting 235/40/19 in the fronts would pretty much fix this problem? thank you so much!! i should have just gotten the tires instead of listening to the tire shop telling me i didnt need to change them out!
Old Apr 30, 2011 | 10:48 PM
Blue Dream's Avatar
235/40-255/40 combination will give you a .6" difference or 2.2% so you should be good. FYI this is a great site to help answer any size questions. Just look for the "diameter" to make your calculations. http://www.miata.net/garage/tirecalc.html
The only issue you might have is finding tires in 235/40. Not many manufacturers offer this size. I thought about going to them in the front but Hankook doesn't offer them. So I run stock coupe sizes 225/40 up front and 245/40 in the rear.
Old May 1, 2011 | 12:27 AM
shoang86's Avatar
thanks! i have hankook evo v12's in the back and after doing some research it looks like 245/35/19 in the fronts will work even though its 4.65% and hankook offers this size (this is a bit high in % but found it in this threat https://g35driver.com/forums/wheels-...thread-16.html)
or i might get 235/40/19 Pirelli PZero Nero
Old Feb 7, 2013 | 08:08 PM
vtngo's Avatar
After I switch the tires back to normal sizes, How long should it take for the ecu to reset?
