RPM's bottoming out and car shutting off
Old Apr 28, 2011 | 05:18 AM
ash1707's Avatar
I have had a couple incidents with my '03 G where the RPM's bottom out and my car completely shuts off. It only seems to happen when I'm driving on the interstate, slow down a bit to get off at an exit, and push in the clutch. The needle falls quickly to the bottom on the RPM gauge and the car shuts off. It doesn't happen every time, but I haven't noticed a difference in anything that I do from when it shuts off and when it doesn't.
Anyone else ever have this problem? If so, how did you fix it?! Thanks
Old Apr 28, 2011 | 05:37 AM
jenxin's Avatar
i read problems where it was the air fuel ratio, did you get a cai recently installed, that might be your problem.
Old Apr 28, 2011 | 05:47 AM
ash1707's Avatar
It has a z-tube installed by the previous owner, but no cai as far as I know.
Old Apr 28, 2011 | 06:39 AM
jenxin's Avatar
i'd try resetting the ecu,
http://www.nicoclub.com/archives/g35...-learning.html
Old Apr 28, 2011 | 09:18 AM
05Scoobyroo's Avatar
I would also try cleaning your Mass Air Flow sensor (MAF). You can buy MAF Cleaner at any autoparts store. Please be sure to only use MAF Cleaner, no other kind!
Old Apr 28, 2011 | 02:50 PM
LoSt180's Avatar
Check for vacuum leaks, any cracked hoses, etc. Replace PCV valve. Also try the link jenxin posted to relearn idle air, and valve close position learning.
Old Apr 28, 2011 | 06:04 PM
monteitis's Avatar
My rpm's used to drop unusually low as well when disengaging the clutch, seemed to happen more often when I had the AC on as well. Not too long ago, I got a CEL indicating a malfunction with the A/F ratio. I took out my intake box, recharged my K&N filter, cleaned all intake parts, and also cleaned my MAF sensor with MAF cleaner. I cleared the code, and it hasn't come back. Also, my rpm's do not dip as severely anymore.
To make a long story short, +1 to what Scoobyroo said!
chinee
Jun 10, 2024 07:48 PM
Joshua615
Aug 31, 2015 12:29 AM
slider_ua
Jul 29, 2015 04:17 PM
apintojr
Jul 23, 2015 10:52 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
