one side lower than other?
Old Jun 16, 2011 | 10:56 AM
  #31
R10T_x's Avatar
^^ damn that sucks
i have the same problem with my stechs let me now if one of you figure it out
also i heard cutting one of your springmounts and not the other could be bad for the car in the long run either cut them both or dont cut them at all
Old Jun 16, 2011 | 11:37 AM
  #32
sTeadFasT96's Avatar
My rear's are the same. The passenger side is 1/4" taller than the driver side. Also on full tank of gas. I thought I was going crazy at first as well, but it's an easy fix as I'll be doing the springmount mod sometime soon. Just chop an extra 1/4".
Off topic, but my Z S-Tech does not seem to drop that low compared to OP's pic. If anything my driver side (the one that is lower) looks like his passenger side....hmmm...
Old Jun 16, 2011 | 01:01 PM
  #33
krypton's Avatar
sTeadFasT96 are you running stock now ? mine are stock
Old Jun 16, 2011 | 01:33 PM
  #34
dofu's Avatar
20 Year Member
Originally Posted by iiiiiekoiiiii
Im sorry but u sound like u dont know **** about this cars suspension.
1 Bolt that holds the bucket for the spring.
1 bolt that holds the strut from bottom
3 nuts on top holds the strut in place...
Obviously I don't because I've never had a problem with this with any suspension on any car.
Old Jun 16, 2011 | 01:35 PM
  #35
Stock what? I'm on 350z Tein S-Techs without the springmount mod. Stock OE 19's with OE size tires.
Old Jun 16, 2011 | 11:57 PM
  #36
silver9's Avatar
I'm on z springs and I rub on the drivers side rear fender but not the passenger side. So same here...
Old Jun 17, 2011 | 08:37 PM
  #37
dpl.ex07's Avatar
same problem with my coils, it seems a lil lower on the driver side rear than the passenger rear
Old Jun 17, 2011 | 08:58 PM
  #38
k67p67's Avatar
Differences in camber can also affect ride height.
Old Jun 17, 2011 | 10:58 PM
  #39
lilindienplaya's Avatar
its normal for our cars to be like that, ive talked to many G/Z specialists and they say the height difference is common. Only think i can recommend is cut the spring mount a little more on the higher side to bring the rear fender gap to the same height.
Old Jun 18, 2011 | 09:42 AM
  #40
R10T_x's Avatar
+1 if one side is 1.9 and other is 1.7 it'll make a difference
at least thats what everyone keeps telling me
Old Oct 23, 2011 | 12:01 PM
  #41
dan|el's Avatar
Any updates on this? What did you end up doing?
Old Oct 23, 2011 | 12:40 PM
  #42
I dunno about OP but I'll be doing the springmount mod soon.
Old Apr 27, 2015 | 06:48 PM
  #43
Drifter2090's Avatar
Damn, I have the same problem...... All the threads just end w/o a solution
Old Aug 6, 2016 | 09:33 PM
  #44
BradMD_96's Avatar
It's 2016 now so has anyone succeeded in leveling the car left to right?
My driver side rear is at least 1/2 inch lower than the passenger side rear so it rubs a fair bit.
I tried to level it out by adding 1/2 inch cut out spring mount onto the existing spring mount - on the driver side rear - but the car just sits exactly the same!
Old Aug 14, 2016 | 12:09 PM
  #45
BradMD_96's Avatar
bump for help!
