gas mileage
Old Nov 22, 2004 | 11:51 PM
omygride's Avatar
gas mileage
does the z tube help or hurt with gas mileage~? thanks!
"your g is fast and furious, my mazda is quick and angry"
Old Nov 23, 2004 | 12:34 AM
GRider35c's Avatar
Re: gas mileage
it insignificantly helps...
Old Nov 23, 2004 | 09:53 AM
Q45tech's Avatar
Re: gas mileage
Air filter nor intakes have any real measurable restriction until the throttle body is WOT and the rpms climb above say 4,000 rpm. Nissan designs everything to be minimal until torque peak rpm where it might be 1% from atmosphere all the way to cylinder..........at HP peak rpm it might double!
The throttle body plate is always the greatest restriction when even 75% open.
Cruise steady rpm mpg is just a function of displacement and O2 sensor accuracy and rpm.
Every 0.005 mpg counts as US government taxes the car manufacturers. Not much any normal human can accomplish to improve the design as they are tweeked to the nth degree.
Most aftermarkets do little if anything.........if the HP goes up [rarely much] the mpg has to go down as each HP requires ~~0.45 pounds of fuel per hour to create
Old Nov 23, 2004 | 10:16 AM
omygride's Avatar
Re: gas mileage
thanks tech~
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rinaldi
Dec 2, 2015 05:29 PM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
wow600rr
Sep 28, 2015 11:50 AM
