First oil change..Need experienced opinion!
Old Jun 13, 2011 | 04:32 PM
fdimola51389's Avatar
I just turned 61k in my 05 coupe and im stuck between two choices. I hear our cars are "sensitive" with the oil we use so i was gonna go with mobile 1 5w-30. What im curious about is seeing the mileage i have would it be better to go with a 10w-30 oil considering the wear on the engine? Thanks alot guys
Old Jun 13, 2011 | 04:45 PM
iamericgee's Avatar
i got 2 words for you !
Old Jun 13, 2011 | 05:03 PM
Im well aware of searching forums friend! but i unfortunately do not have that luxury seeing how i only have computer access at work. A straight forward simple answer would really help though!!
Old Jun 13, 2011 | 05:08 PM
brandon402's Avatar
Go with what weight is recommended from factory. And I highly recommend the German castrol. Thats some good stuff and, once you get the opportunity to take advantage of the recommendation made by iameric, you'll see that some folks put alot of effort into researching the stuff.
Old Jun 13, 2011 | 05:28 PM
the04coupe's Avatar
I always go by the general rule thicker oil in the summer and thinner oil in the winter . As for brand I have always just used castrol syntec . Theres always better and full synthetic oils but it does the job .
Old Jun 13, 2011 | 07:53 PM
rimshaker's Avatar
Just stick with stock 5w-30, and go full synthetic.
If you live in FL, temps don't get cold enough for the "W" numbers to matter anyway.
Old Jun 13, 2011 | 08:06 PM
gary c's Avatar
You could easily use Mobil1 10W/30 if you want, it won't hurt a thing that's the weight I use here in CA. It would be a good idea to use their filters too and change it every 4K miles, your G will be happy you did!
Gary
Freeman186
Sep 6, 2023 10:07 AM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
CV35Driver
Sep 15, 2015 05:09 PM
UT G35
Sep 3, 2015 03:58 PM
