Front tires work on 19 inch wheels:235/35/19????
Old Jun 16, 2011 | 07:09 PM
Realtor's Avatar
Hello everyone,
I have the 19 inch rays with 225/40/19 in front and 245/40/19 in the rear.
My friend has some 235/35/19 tires off his 911 he will give me if they will work on my car? Pzeros, he went Michelin sports all around and did not want to mismatch.....Anyways,
I was told at Infiniti that it may cause my traction control to activate due to the difference versus stock? Does anyone know if this to be true or can I run these tires with no traction control/VSLD issues?
thanks for the input....
Old Jun 16, 2011 | 07:28 PM
walshtj's Avatar
They will work but your speedometer will be off since your changing your overall rolling radius. No issues with VDC, plenty of members and z owners run that setup and some that are more aggressive.
Old Jun 16, 2011 | 08:58 PM
herrschaft's Avatar
They will fit, I'm running 245x35x19's on the front. As long as the overall diameter of the front and rear tires are close there will be no VDC issues.
Use this: http://www.miata.net/garage/tirecalc.html
Old Jun 16, 2011 | 10:26 PM
Calamity's Avatar
I run a 245/35/19 as well, you'll be fine
Old Jun 16, 2011 | 11:47 PM
4D05G35's Avatar
Originally Posted by Realtor
Hello everyone,
235/35 is on the small side which probably willl cause issues. 235/35/s are about 4.7% smaller than the rear which will probably cause VDC issues .
Old Dec 28, 2014 | 12:36 AM
G35_josue_562's Avatar
So will or not work to run 235/35/19 front and 245/3/19 rears? I'm also facing this issue myself and want to get some clarity on it as well I don't want to have any issues with vdc kicking on with this set up.
Old Dec 28, 2014 | 01:18 AM
bluedevils95's Avatar
You'll be fine. A lot of ppl is running staggered set up. I am sure your not going to floor is every time to have the VDC kick in. In my other car I am running stock set up and if I get in the pedal I can have the VDC kick in. You will be fine. Just don't drive crazy that you lose control of your car
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
rping
Jul 26, 2015 09:53 PM
jimNC
Jul 25, 2015 05:47 AM
realtalk21
Jul 20, 2015 09:07 AM
Soumilg
Jul 18, 2015 12:33 PM
