Front Bumper Damage
Old Jun 18, 2011 | 02:06 PM
deathsupport's Avatar
Front Bumper Damage
Hey guys, please see attached photo for picture of the damage.
This happened (admittedly) a while ago when I was backing out of my driveway and the snow was concealing a spherical ornamental stone.
It's actually quite inconspicuous until pointed out so my biggest concern is getting the proper shape back... touch up paint can be done later.
I'm wondering what's the best way to approach this. I can actually get my hand in and feel the dent from the inside but I'm not sure if I'll be able to pop it out.
I have a heatgun somewhere and would want to avoid removing the front bumper if possible. Any suggestions?
Old Jun 18, 2011 | 02:40 PM
DailyDrivenCoupe's Avatar
i accidently did this with the front of my bumper in the middle, tho it was on a curb. i was able to push mine out tho, and then put a lip on to cover it up. i say push it out and work from there
Old Jun 18, 2011 | 02:42 PM
You pushed it out same way I described I'm guessing? Without removing anything just pushing that bottom plastic guard out of the way?
Old Jun 18, 2011 | 02:45 PM
just go in through the fender wheel and actually push it out. and then go on about touching up the paint as best you can i didn't do mine all that perfect but i have a lip now so you cant ever see it
Old Jun 18, 2011 | 03:04 PM
Xet's Avatar
Xet
how did you get a hit like that backing out??
Old Jun 18, 2011 | 03:19 PM
Hmm.. I just tried and it's a bit harder than I though. I removed the black covering in the fender as best I could (it's still screwed down and my attempts at unscrewing just ate away at the screw) and got my hand in but there's other stuff in the way. Really need to apply a lot of force. Just realized my heatgun isn't with me so it might be a while. Also tried from beneath again but not enough strength in my fingers to push anything out.
@Xet lol I was anticipating this question. My friend parked poorly on the driveway and I had to come close to his car and 'swing out' last second to get out. Unfortunately swinging out got me in contact with that stone which I didn't even know existed.
Old Jun 18, 2011 | 03:23 PM
walshtj's Avatar
^ Sucks. I would suggest jacking it up and that might help get move room to push it out.
Old Jun 18, 2011 | 04:40 PM
Mark2K8's Avatar
At least its in a spot in which a lip can cover it up!
I dented/scratched the rear bumper, but if i were to get splash guards they wouldnt be high enough
Old Jun 18, 2011 | 04:41 PM
Eric@TCGMiami's Avatar
Get a blow dryer....
Swiftly move it back and forth, the heat will pull the bumper out without messing up the paint.
Old Jul 19, 2011 | 06:50 PM
Sorry for thread resurrection but finally got a hold of the heat gun. Held it to the damaged spot for about 30 seconds and it popped right out. Took a little more time for 'tweaking' and although it's not perfect shape once I clean and paint it it should look good.
Picture attached as proof-of-concept in case anyone needs this in the future.
Tukeeg35
Sep 27, 2015 12:16 AM
derres
Aug 28, 2015 03:27 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
st33zygill
Jul 29, 2015 10:05 PM
