Where Can I Get A Keyfob Remote??
Old Jul 1, 2011 | 01:15 AM
03XG35's Avatar
I just found out my remote is for a completly different car. I went to infiniti today and they said they'd charge me $160 just for the programming. I see some on eBay for around $50. ANy stores I can go to? Sites?
Old Jul 1, 2011 | 12:38 PM
TripleHBK's Avatar
Pick one up off of ebay... Here are the programming instructions. I bought mine for 18.99+ shipping last year and it works perfectly...
This is also the seller I purchased from: Here
Programming 2003 to 2007 Infinity G35
When
Remote transmitter added or replaced.
System malfunction.
How
NOTE: A maximum of 5 remote transmitters can be programmed.
Obtain all remote transmitters.
Close all doors.
Insert and remove key from the ignition switch more than 6 times within 10
seconds.
Indicators will flash twice.
Insert key into ignition switch and turn to ACC position.
Press any button on first remote transmitter to be programmed.
Indicators will flash twice to confirm correct programming.
Oldest remote transmitter code is now erased.
To program next remote transmitter:
UNLOCK then LOCK vehicle using the LOCK/UNLOCK switch on the driver's door
control panel.
Press any button on second remote transmitter to be programmed.
Oldest remote code is now erased.
Repeat above procedure to program remaining remote transmitters.
To exit programming mode: Open driver's door.
Check operation of all programmed remote transmitters.
NOTE: Remote transmitters can also be programmed using diagnostic equipment.
Please read all of the information provided thoroughly. This is designed to
try and assist you in the successful programming of your remote in a minimal
amount of time with little frustration. Procedures vary from vehicle to
vehicle. Some are easier than others. Some require skills not everyone has.
All remote programming must be done with the vehicle. There is no way to
pre-program any remote to a vehicle in advance. Nearly all vehicles require
all remotes you intend to use for a given vehicle to be present, and to be
programmed at the same time. In most cases all previously programmed remotes
will no longer be operable once the procedures have been performed for your
new and existing units.
NOTE: Prior to beginning the programming procedure sequence,
be certain to turn off all fans, and any other vehicle devices that may
be operating, especially radar detectors as these items may prevent
the proper programming of keyless remote fobs. Absolute silence is
often very helpful and necessary in order to hear any small lock
cycling noises on many vehicles, especially many Honda's & Acura's.
Heavy traffic noise, barking dogs, or crying children may make it
very difficult to impossible to accomplish the task.
Programming the remote is usually a two step process.
Step one is to get the vehicle into the programming mode.
This makes the vehicle ready to accept the remotes. On many vehicles
you do not even need the remote until you get to the second step. A few
vehicles programming procedure requires a mechanical ability and an understanding
of terms used in the instructions. If you have no mechanical ability,
or are not familar with terminology, then you need to seek the assistance
of QUALIFIED HELP to get these done. We will not be able to teach you about
the terms and procedures involved. Most vehicles are much more simple
than that, but will generally require some persistance and determination
to get them done. It can be frustrating at times, and often takes us numerous
tries to get these done. Do not be dismayed. Read the instructions thoroughly,
and try to understand them before making any attempt to actually accomplish the
programming. You can not do the sequence once or twice and throw your hands in
the air and say "it does not work." With a little perseverance and a thorough
understanding of the procedures, most folks are able to get this done in a
relitively short period of time.
Step two is the actual programming of the remotes to the vehicle.
In most cases, If you did not get the vehicle into the programming mode,
then you are not even up to the remotes themselves yet. You may have an issue
with the car itself and more likely you have made an error in the procedure
Sometimes going faster or slower can be the key to success.
Numerous people swear they have followed the procedures "to the letter,"
and are not successful with the programming. Most often, they have not
actually followed the sequence properly. Any small error in sequence, or
exceeding mentioned time limits will result in a failure to obtain the
desired results. If the timing is very short, and you have to go back and
read the instructions, you have in all likelyhood exceeded the time limits
and you will be unsuccessful. Some people still have difficulty and just
can not follow the instructions. We suggest you find a very good locksmith
in your area or go to your local dealer for assistance. Locksmiths are
usually somewhat cheaper than dealers.
IMPORTANT NOTE: If at any time you mess up the sequence or exceed the timing
mentioned in any instructions, start the vehicle, then turn it off, remove
the key, and close any open doors to reset the vehicle back to square
one. Then begin the process anew. This must be done prior to each and every
attempt at programming! Failure to do so will only result in frustration as
you will not be succesful in your next attempt either.
Many programming procedures call for the ignition to be placed in the " on "
position. This is turning the key so the dash lights illuminate....the so called
"idiot lights," come on. This is the position right before you would engage the
starter to start the vehicle. YOU DO NOT START THE VEHICLE !
Disclaimer
We do our best to make sure the information imparted here is accurate.
We will not be held responsible, however, for technical inaccuracies or typographical
errors. We shall not be held liable for damage or loss due to your use of any programming
procedures used from these instructions. We do not make any warranties about the procedures
listed or about the accuracy of the programming procedures. We accept no responsibility for
this content, or other problems that may occur from the use of the programming procedures.
Old Jul 2, 2011 | 12:43 PM
SFG_35's Avatar
carandtruckremotes.com
i've ordered from them twice, remote fob and keys. came with instructions and prices aren't bad. got to my house in less than a week.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
JustinMKN1
Sep 18, 2015 03:40 PM
