If I found some 350z wheels (5 star) will they bolt right up?
Old Jul 6, 2011 | 12:51 AM
tibasnatch's Avatar
I think I may of found some 350z wheels...the 5 star design....will they bolt right up to my 03 g35 coupe or will i need anything else like spacers....?
thanks
Old Jul 6, 2011 | 12:52 AM
The Stimulation's Avatar
Yes. Same bolt pattern. No need for anything else. Just slap em right on.
Old Jul 6, 2011 | 01:06 AM
tibasnatch's Avatar
Great, guy just listed a set on for $300...hope i can get them.
Old Jul 6, 2011 | 01:09 AM
HenryLee's Avatar
yes
Old Jul 6, 2011 | 10:05 AM
gary c's Avatar
Not just yes, of course....
Gary
Old Jul 6, 2011 | 11:50 AM
tibasnatch's Avatar
great going to get them now.....will the tires i got be fine now...fronts need to be replaced...but need to be 225/45/18 right?
my rears are fine and have alot of life left and they are 245/45/18
thanks
Old Jul 6, 2011 | 12:09 PM
Xet's Avatar
Xet
Are they oem 350z? What are the widths and offsets?
Old Jul 6, 2011 | 01:55 PM
gwood5turbo's Avatar
245 on rear? wow. My set up is 235 front 275 rear.. and I want to go wider!
Old Jul 6, 2011 | 02:39 PM
tibasnatch's Avatar
Just got back....got the oem 5 spoke 5 star anniversary wheels for $260..
they are 18x8 up front and 18x8.5 in the rear....the tires I have now are 225/45/18 in front and 245/45/18 in rear those will work fine right?
thanks I got a steal!! very happy
oh and they still have the TPMS on all 4 wheels....I guess I take those off and put regular valve stem? and are the TPMS worth anything?
Old Jul 6, 2011 | 02:56 PM
TPMS can be calibrated for your vehicle, but it will cost you. I dunno but I think only the dealer can do. You can always drive without them, you'll just see the low tire pressure light brighten up on your dash every time. Just keep an eye on air pressure periodically. And yes, you can sell the TPMS in the marketplace. Do a search in the marketplace to see how much they go for, I forget, but you'd have to sell it on the Z forum since it would apply more over there since they are Z wheels.
Old Jul 6, 2011 | 03:00 PM
irishsig's Avatar
thanks
They will bolt right on, but they'd look better with some wheel spacers.
Flush always looks better than tucked.
Old Jul 6, 2011 | 03:02 PM
tibasnatch's Avatar
Ok thanks.....so just my fronts need to be replaced tires.....should i go with what stock is at 225/45/18?
thanks
Old Jul 6, 2011 | 05:30 PM
MurByrne's Avatar
I'd love to see pics once they're on
Old Jul 6, 2011 | 05:48 PM
tibasnatch's Avatar
will do...
1 more question still needs answering please.....my front tires i gotta replace....what size should I get the stock size is 225/45/18...do i need those.....
also i found some 225/40/18 that are a bit cheaper and those are easier to find it seems.....which tire size should i go with?
thanks
I will get pics once on...hopefully tomorrow
Old Jul 6, 2011 | 06:47 PM
Hondahunter2101's Avatar
350z Wheels
I recently got a set off an 08' 350z. They bolted right on and look amazing. IMO, better than the Infinity 18s. I recommend spacers though. I went with 25mm all around and they are perfectly flush with the fenders. Also, the center caps are interchangeable.
