Help! tire pressure on my 19" rays!
Old Aug 2, 2011 | 02:40 PM
l3adabing's Avatar
Arrow Help! tire pressure on my 19" rays!
Hi,
I was originally using 18" oem rims and have just recently switched over to oem 19" rays. The problem is that my "Low Tire Pressure" warning light has come on. I have checked all the tire pressures they are all around 33 psi which is basically what they should be. I dont know why the warning light is on or how to get rid of it! let me know what you guys think! Thanks
Old Aug 2, 2011 | 02:52 PM
MADtotheA's Avatar
Probably a bad tpms sensor.
Old Aug 2, 2011 | 02:55 PM
toogood131's Avatar
You gotta transfer the sensors from your 18s to your 19s, they are ecu specific. Also remember to put them on the same wheel, ie the one from your front driver 18, but on the front driver 19.
Old Aug 2, 2011 | 03:07 PM
koldtek's Avatar
You need to reset/re-calibrate the TPMS sensors on the 19's. I had this issue, took it to the dealership and they reset it. Works fine now.
Old Aug 2, 2011 | 03:17 PM
saywat?'s Avatar
tire pressure should be 35psi i usually put 36psi
Old Aug 2, 2011 | 03:32 PM
AuAltima3.5's Avatar
Just need to "sync" them to the car. I don't know a DIY for this and seems to be a dealer only process. Besides the annoying light you are fine.
Old Aug 2, 2011 | 07:28 PM
TripleHBK's Avatar
Yep... Manual says 35. I run 40 in the rears myself. Also, after the light comes on it doesn't go off immediately.. you have to drive about a block before it notices that everything is ok.
Old Aug 2, 2011 | 07:44 PM
saywat?'s Avatar
^interesting. sometimes people put more in the front to compensate for the front being heavier
Old Aug 2, 2011 | 07:53 PM
gary c's Avatar
You TPS are set up for your ECU, all you need do is have them installed in those new Rays. I've had mine in several set of wheels and they work fine once installed.
Your manual/door calls for 35 psi, I run 37 psi and my tires wear even. I tried 40 and it felt terrible, amazing 3 lbs will change how your G feels/rides!
Good Luck! Gary
Old Aug 9, 2011 | 07:47 PM
l3adabing's Avatar
hmmm thanks for the help everyone! i will go have have the TMPS sensors changed then at a dealership. But for now, i will just have to put up with that annoying light. haha
willdogs
Dec 8, 2015 11:32 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
JoeMac
Aug 20, 2015 10:17 AM
