Ahhh..Help With Part Please
Old Aug 9, 2011 | 12:46 AM
culi's Avatar
Broke Pulley Tensioner Bolt
I tried to change my serpentine belts out today and broke my tensioner bolt for the AC compressor.
Here is the story, so I loosen the idler pulley nut for each belt. Then I proceed to loosen the tension bolt on the power steering pulley and the idler pulley lowered. When I tried to do the same for the AC compressor side, the tensioner bolt was tight. I couldn't hardly turn it at all. Yes I know my lefty loosey and righty tighty. Anyway, so I took the tension assembly off with the idler puller. I used PB Blaster and it still wouldn't budge. So I used a little too much force and it broke. Sigh.
So my question is, do you know the part number for the bolt that I can order through dealer or infinitipartusa? I couldn't find the part number on infinitipartusa site. This is what I found. Is this correct?
http://www.autopartsworld.com/result...5L,universal:0)
Speck102
Mar 26, 2018 11:48 AM
Greg Huston
Sep 25, 2016 11:36 PM
DarkLyter
Jul 28, 2015 04:57 PM
