hey all, so i buy this Nismo grounding kit from an ebay auction. great deal as it was only about 28 dollars including shipping. the problem is is that it seems to be a universal kit. i would take pics but my camera in getting fixed. anyway, it consists of seven wires all attached to a circle flat metal piece which ties in alll the wires, a set of nuts and bolts, and what seems to be a battery adapter for what i assume is one of the crounding points. lastly a Nismo black plate to cover the circular metal piece. unfortunately, nothing else come with the kit like where to ground the wires, how, etc etc. anyone know where the grounding points go? is there a site with instructions? do the more expensive grounding kits come with more wires? please help. thanks RX
I couldn't find any good instructions online, but this pic shows where five of the wires can go. I would try to mount the plate to the front of the engine where you see the 3 wires attached. Run one to the battery, one to top left of plenum, one by the throtte body, one to lower left of plenum, and one to the frame in the lower left of the pic. I only have a 5 wire kit so I can't help you with the last two. I remember when you posted that you bought this and suspected you might run into some trouble. Hope this helps:
thanks for the help but honestly i would need a better pic for some of the points. not sure why i got 7 wires if the standard is 5. how much did u pay if u dont mind? actually these cables are really good material and construction not sure the gauge but heavy enough. they however are blue and i wanted red to match the car color. anyway, any more info would be appreciated. i will get a hold of the seller as wel. thanks again Rx
hey does the round ring attached to all the wires in the packet get mounted onto something? and then all the ends of the wires go to other points including battery? and btw, does it really help much? Rx honestly bought it cause it was cheap but maybee should have held off. but quality is good. thanks RX
RX,
Search the DIY section, they have info on grounding kit (custom for G35) it may help you, Please post once you complete the install and tell usmif you seen any type of improvement.
Thanks
Thanks
