Idler Pulley Problem
Old Aug 21, 2011 | 02:28 AM
culi's Avatar
I need help. I recently disassembled my AC idler pulley and mounting bracket to changed my drive belts because I broke the tensioner bolt. I got everything back together and now having rubbing issue on the pulley. The black plate between the pulley and the nut is rubbing on the pulley itself. I know there is a spacer in the back (with larger inner diameter) and a spacer in the front (with smaller inner diameter) and the plates that cover them. I installed the plates correctly. When I tighten the nut down, the pulley would rub against the front plate causing it to loosen when I turn on the engine. Am I missing something? Another spacer perhaps?
Old Aug 23, 2011 | 11:38 AM
culi's Avatar
Nevermind. Solved it by adding a washer between the plate and the front spacer to provide clearance.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
