HELP! need correct sizing of nuts for OEM hood!!
Old Aug 28, 2011 | 07:20 PM
laksjd84's Avatar
G coupe owners, I need your help.
I need to find out the correct sizing of 4 nuts that holds the hood down to 2 hinges. OEM hood got a built in stud and its tightened down to the hinge by lock nuts. I have tried every possible size but no luck. if someone can simply get the nut sizing with few tries of sockets, i would really appreciate it.
I attached a picture for illustration. Two nuts used to tightened the hood hinge to the hood (not the body). top two nuts right next to NRG damper. You have to remove a plastic cover to find out the nut size.
If you can , please text me the correct sizing (thread pitch also) to 773-531-3551. or just reply here or PM.
Thanks in advance
Old Aug 28, 2011 | 08:53 PM
laksjd84's Avatar
bump
Old Aug 28, 2011 | 08:57 PM
herrschaft's Avatar
I think they're 14/15mm, don't have my car to confirm though.
Old Aug 29, 2011 | 02:03 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Mine was either a 10mm or a 12mm.
I'm always switching hoods out, going from my HD to my OEM. I know my HD is an 11mm and I always forget if the OEM is a size up or down from that.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
