TPM Problem
Old Sep 2, 2011 | 12:31 PM
lcysimon's Avatar
TPM Problem
Just wanted to see if anyone had this TPM issue.
My TPM light comes on and flashes for about 15 seconds, then stays on after I start my car.
The story:
1. One morning, I went to check my tire pressure at a local gas station. It showed 45 psi and I immediately dropped it down to 38. Little did I know later that the air pump had issues.
2. 2 days later, TPM came on in the morning. I went to correct all tires to 38 psi (It was actually sitting at 28psi!), but my TPM continued to stay on. I even checked late at night to ensure it's reading all 38 psi.
I've also checked to ensure that there are no nails on my tires and I did monitor individually for 2 nights.
I've been driving with the TPM light on for about 100 miles now, so any adjustments that require time should be read by now. So what is wrong with my TPM?
If the TPM sensors are dead, then how did it catch my 28 psi?
Has anyone went into this issue before? That light is really annoying and I really want to get rid of it... After all, the TPM is suppose to be a safe feature.
Thanks for your help in advance
Old Sep 2, 2011 | 03:47 PM
Kayzer Soze's Avatar
im sure a garage that does tire installs can reset it worst case
Old Sep 2, 2011 | 05:15 PM
TripleHBK's Avatar
Not sure what the big deal was... I've consistently run between 40 and 45 psi in my rear tires for years without a single adverse effect. Unless you're looking for every feasible competitive edge on the track, and/or your driving conditions are extreme, then the difference is/was really negligible.
As for the light being on. try unhooking the battery for a few minutes forcing a reset of the cars computer. Ensure your tire pressure is accurate, re-hook everything up, and then see what happens. It's very possible you have 1 bad sensor and it's tripping the whole shebangabang.
Old Sep 2, 2011 | 05:28 PM
lcysimon's Avatar
I don't track my car at all, but 40+ psi made my car very bumpy and I wouldn't go back to that. To clarify, I have oem 19s with 225/40/19 and 255/40/19.
Good point, I will try to reset the battery to see if that helps. Thanks!
Old Oct 5, 2011 | 02:34 PM
lcysimon's Avatar
Just a follow up, I took my car to Nissan and they said that my front left TPM had low battery and needs replacement. Part ~$120 and labor another $120-150...
I am a bit confused that these TPMs actually have a battery life. If that is the case, shouldn't all 4 TPMs die at around the same time if they all come with a battery life? The last thing I would want to see is to replace one every year...
Anyone know the answer for that?
Old Oct 5, 2011 | 02:38 PM
gtoor1990's Avatar
not just with infiniti but im starting to see man cars have problems with there tpm sensors.
Thebaws11
Jul 2, 2021 11:36 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
mattdg35
Sep 14, 2015 11:28 AM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
