cam & pulley up grades
Old Sep 11, 2011 | 08:49 AM
TruGame's Avatar
Hello my G35 fam i have a LR 05 G35 with 100k on it as of today im looking at putting AMS pulleys and changing the cams to Brian Crower Stage 2 Cams, has any one here changed the cam shafts ??
Old Sep 11, 2011 | 10:36 AM
G35 Dream's Avatar
Talk to SexyRob. He put nismo cams in his.
Old Sep 11, 2011 | 09:06 PM
HotRodG35's Avatar
Ive done BC stage 2 and stage 3 cams. If you stick with cam swap only valve clearance should not be an issue, still needs to be checked. If you change valves than most likely will need to change valve buckets to get proper clearances.
I changed valves/springs with my build using BC stage 3 cams and needed to adjust clearances. I did cam swap with BC stage 2 on CUX350z engine and clearances were good.
Old Sep 11, 2011 | 09:18 PM
TruGame's Avatar
HotrodG35 with the BC stage2 cam could you feel the Hp gain and how much HP did you gain
Old Sep 12, 2011 | 06:17 AM
HotRodG35's Avatar
The BC stage2 cam swap on CUX350Z was done same time built engine and TT install. I did the BC stage 3 cam install with new full built engine, upgraded supercharger and exhaust. Either case could not just isolate camshaft performance gain.
You should see about 20 RWHP gain NA, and double that FI. Its all based on supporting mods. The camshafts will work better with High Flow exhaust and intake. Long Tube headers will provide better gains than short tube headers. Use a Motordyne spacer or Cosworth intake.
I'm sure thier will be others to chime in on thier preferences for INT/EXH. This should give you a starting point.
Remember the more air/fuel engine can effectively combust on every stroke the more power engine makes. Using upgraded camshafts without improvements in INT/EXH will only provide minimal gains.
Old Sep 12, 2011 | 09:19 AM
TruGame's Avatar
Thank you hotrodG35 for the info I'm gonna order the BC stage 2 cams and long tube headers, it said that I'm able to just drop it in and I'm good sssooo I want need a tune right
Old Sep 12, 2011 | 09:36 AM
GreenGoblin's Avatar
The goblin resurrection
I did my bc2 cams on my greedy stock block and it really woke up the midrange to top end. I am making more power with less boost now. Also it's not hard, if you can diy then it makes it even better.
Old Sep 12, 2011 | 12:12 PM
HotRodG35's Avatar
Its recommended to get a tune up, unless you have a means of monitoring A/F because it will definately be affected by cams/headers.
I ordered my BC camshafts from Injected Performance and paid less for new ones than what I've seen used ones sell for on forum.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
CV35Driver
Sep 15, 2015 05:09 PM
UT G35
Sep 3, 2015 03:58 PM
