Slight rattle when in neutral sometimes..
Old Sep 18, 2011 | 12:19 AM
dmarz45's Avatar
So I just bought an 03 G35 coupe 6 speed yesterday. Sometimes when I'm in neutral (on a hill it happens sometimes) the car has a very slight rattling noise. You can only really hear it if the window is down. Is this normal? Also the stick shift vibrates slightly when this happens. Is this normal or is this a bad sign??
Old Sep 18, 2011 | 09:24 AM
gary c's Avatar
I believe what you're hearing is the throw out bearing, they chatter with age....nothing serious.
Gary
Old Sep 18, 2011 | 09:33 AM
IIIHawKIII's Avatar
see if it's the same rattle as when you shut your car off, in neutral, with the clutch out. then shut your car off with the clutch in. if so, it's normal.
Old Sep 18, 2011 | 12:12 PM
RyanV's Avatar
It's probably the springs on the clutch disc rattling. If your in neutral(especially with the AC on) they can rattle.
Try depressing the clutch in neutral to see if the springs stop rattling when the disc releases from the flywheel.
This can happen even more with a lightweight flywheel.
My Sc300 does this only with the A/C on, without the A/C there's no spring rattle.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
dcsbh1
Oct 1, 2015 03:15 PM
