Stiff Shocks/Struts and loose rear end?
Old Oct 2, 2011 | 01:46 PM
PEARL-G's Avatar
Hey guys, any recommendations for a set of stiff shocks/struts combo? ill have the eibach sportline kit too. i have a pretty heavy system in my trunk so im just looking for pointers thanks guys!
hmm, also my car is all over the road at like 30 + in the rain or when i hit bumps u can feel the car shift from side to side, do you think it could be cause my suspension is old? 80K & stock??
Old Oct 3, 2011 | 12:51 AM
MADtotheA's Avatar
Get some 350z springs, they are stiffer then g35 springs. Tokico D-spec would be a good choice for shocks or tokico HP if your are on a budget. How are your tires? That may be the cause of your shifting side to side unless your rear sway bar is gone lol
Old Oct 3, 2011 | 06:09 AM
4D05G35's Avatar
Coilovers so you can set them up how you like.
As far as the rear shifting on bumps, it could be your alignment, or your tires. I would check both of those out first. If the tires are good then I would swap the suspension to what you want, then get an alignment since you will need one anyways.
Old Oct 3, 2011 | 06:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
It's a complete waste of money IMHO to replace your worn-out suspension with new shocks/springs if you're looking at adjustable shocks. Look into a decent set of coilovers like the BC that you can get for under $900 if you shop around. That way you will have a set up that was designed to work together and you have complete control over ride height and dampening. I wish I had listened to that advice when I first bought my car. After trying 3 different spring/shock combos I finally got coils and will NEVER go back.
Old Oct 3, 2011 | 10:58 PM
PEARL-G's Avatar
hmmmm, thanks guy for your help!
Old Oct 3, 2011 | 11:11 PM
wbama387's Avatar
yes coilovers are what you need to go with. I have the tein monoflex.
Old Oct 3, 2011 | 11:22 PM
PEARL-G's Avatar
I know coilovers are the best, but they are just so damn expensive. I think I'm gonna go shock/springs, mainly cause I'm only gonna have this car for 2 more summers before I upgrade. I'm thinking the tokico / eibach setup. And I may cut another 1/4 inch off the spring mounts too idk. I only have 1 more month before it's garages anyway
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
Ken167
Aug 7, 2015 11:12 AM
atk08
Jul 30, 2015 03:12 PM
