Next Mod Big brake kit or coilovers?
Old Oct 6, 2011 | 09:34 PM
BALLER005's Avatar
Got my new wheels in vetting magic going for the hella flush but look can't do everything in one month so should I drop it space the wheels and stretch the tires first or get the big brake kit
Brakes are needing to be replaced soon though
And if I do the brakes might as well put on front spacers to
What would you do?
Old Oct 6, 2011 | 09:38 PM
chink-ah-saur's Avatar
Drop
Old Oct 6, 2011 | 09:39 PM
oneup's Avatar
Coils!
Old Oct 6, 2011 | 09:40 PM
ConradoR's Avatar
IF the brakes are bad, obv. go safety first and get the brakes. If they are still good for a few thousand, go coils.
Old Oct 6, 2011 | 09:41 PM
dEnbOy.GFM's Avatar
Depends on what you're trying to accomplish...
If you're working on the stance stuff, the most relevant thing out of the two would be a drop... But if your brakes go before you can get brakes then the smart thing to do would get brakes first....
Old Oct 6, 2011 | 09:45 PM
BALLER005's Avatar
I really just need pads which I can replace I can last another month on brakes
But I'm going for a semi hella flush look
Old Oct 6, 2011 | 09:53 PM
FreshG's Avatar
drop will change the whole look of your car.
Old Oct 6, 2011 | 09:56 PM
Canadiotica's Avatar
What he said
Old Oct 6, 2011 | 10:23 PM
jef_gutjr's Avatar
OP, if your brakes are about to go, I would do the brakes first and the spacers. Although, since you have an aggressive set of wheels, putting some coils will compliment the set up. Overall, if your brakes are almost metal to metal then i would go safety first and go with the BBK set....
Old Oct 6, 2011 | 11:45 PM
walshtj's Avatar
+1 but if not then coilovers.
Old Oct 7, 2011 | 12:06 AM
Deezflip's Avatar
...drop/coils first,
...then stretch tires
...then measure gap and get the correct size spacers
...done, possibly moar low if wanted
Old Oct 7, 2011 | 12:07 AM
Ye_Budyy's Avatar
coils for sure
Old Oct 7, 2011 | 06:41 AM
Blue Dream's Avatar
I drove ttrank's car solo
I vote coils as well. Unless you plan on tracking your car a BBK is just for looks only. Get a set of inexpensive pads for the time being and enjoy the benefits of coils!!!
Old Oct 7, 2011 | 09:57 AM
BALLER005's Avatar
I ordered the Coilovers this morning
and rear tires to get stretched
ill do the spacers and camber kit next month
and just put in some cheap pads
big brake kit will be pushed back to DEC
Attached Thumbnails Next Mod Big brake kit or coilovers?-11.jpg   Next Mod Big brake kit or coilovers?-111.jpg
Old Oct 7, 2011 | 10:13 AM
Good man.
