Best place to order a fender???
I need 2 drivers side fenders. One for an 03 and the other for an 05. Where would be the best place to order them??? I know we have a few guys that work at dealerships here so maybe they could help out. Thanks......
You also have the option of checking out your local Nissan/Infiniti wrecking yard for a pair of mint fenders. Even new fenders will need to be prepped so used fenders in mint condition shouldn't require any more labor and cost considerably less.
Gary
Gary
A local yard isnt an option and the Nissan dealer is asking more that 400 a fender unpainted. I was leaning toward an ebay alternative if i cant find them from a parts source here on driver.....
Your best is going to a junkyard even if you have to travel for a bit. You can pick up 1 for about 200$ try and get one with just a little dents here and there. (Remember you are gonna be having it painted so it can be repaired properly thru that). If you cant then Stealership it is. ...
03 and 05 G35 Coupe (I assume?) fender is the same part number, I have 2 in stock, good news I can sell them to you for $245 each, bad news, if you're not local probably cost more in shipping than it's worth to you........
go for D&H Auto Parts. try the link I left below or look for them on Ebay. I'm in the process of rebuilding my salvaged G35 and they have the cheapest legit parts I've seen. Plus they can paint anything for you and get the color exactly right if you give the paint code.
Unpainted fender goes for around $150, free shipping.
http://www.dnhautoparts.com/search/?...2004&x=49&y=10
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
