I have this used HKS Hipermax LS+ and I don't know this is for 350Z or G35C
the only thing I can see on the part is Hipermax LS+
as I searched on the web and I found there are 3 types of LS+ for G35 Coupe, Sedan, and 350Z
if this is for 350Z or G35Sedan, will this still fit on my G35 Coupe?
they only have different spring rate, so they still fit? but they look weird?
or they just won't fit in my g35 coupe?
found this
HKS LS+ G35 Coupe Monotube construction, adjustable dampners Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 504/448 ( out of production, no longer avaliable )
Side Note: Has the unusual distiction of actually being valved stiffer then the same coilover made for the 350Z (though you can only see 350Z LS+’s in the JDM catalog).
HKS LS+ 350Z Monotube construction, adjustable dampners Rear dampers adjust from the bottom so you do not have to pull the damper to adjust them
Spring rates 448/448 ( out of production, no longer avaliable )
Sidenote: Listed on HKS's Japan web site, but not on the US web site. These might actually be our RS coilover.
sounds like they are same coilovers but have different spring rate...
want to know what happen if 350z's spring rate goes into my G35C? just looks weird?
or it is not good for my car?
found this
They should fit. The 350 and G35 coupe are pretty much the same chassis. Alot of parts, excluding body parts, are interchangeable between the two.
As for them maybe being for the sedan, and if they fit on the coupe, I'm not too sure.
Hard to tell with what you said. Maybe post a pic in the sedan boards and ask there??
thank you!Originally Posted by CheeWho?
They should fit. The 350 and G35 coupe are pretty much the same chassis. Alot of parts, excluding body parts, are interchangeable between the two.As for them maybe being for the sedan, and if they fit on the coupe, I'm not too sure.
one more thing I want to know is that the spring rate for 350Z and G35C is different.
so then what result will I get with this if I put 350Z into my G35C?
just different stiffness?? or different height or what else is there?
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
All coilovers for the first gen Gs and Zs will fit interchangeably. This includes:
03-07 Coupes
03-06 Sedans, excluding the AWD models
03-06 Zs
Don't worry about the height differences if any, that's one of the reasons you buy coils is the adjustability of height and dampening. Higher spring rates mean a stiffer ride,simple as that. Great choice of coils, hope you're getting them for a good price. I'm a little jealous.
03-07 Coupes
03-06 Zs
