Endlink question
Old Nov 12, 2011 | 09:49 PM
crazynuts16's Avatar
Endlink question
I was just going to place my order for endlinks but i got confused between getting the newer ones or the ones specified for my car.
I have a 2003 Coupe, so i went and selected the part numbers for my car and they were:
Front Driver: 54668AL502
Front Pass : 54618AL502
Rear Driver: 54668EG02B
Rear Pass : 54618EG02A
and the newer ones from a 2006 coupe,
Rear Driver: 54668EG01A
So they are all the same part numbers, except the rear driver one, now my questions are:
1. Should i go with the newer one or get the old one?
2. Will there be any fitment issues with the new one?
3. Only my rears are going bad, should i just go ahead and change the fronts too just in case?
4. Does changing these affect alignment? (need this question answered only from someone who is 100% sure on the answer please)
5. Easy diy or get a shop to do it? never done any suspension parts before but from what i saw it was only 2 bolts. need to torque them?
Thanks a lot guys, i searched on this issue but could not find any part numbers so just want to be sure before i order them.
Old Nov 12, 2011 | 10:06 PM
HotRodG35's Avatar
To answer your questions:
1. Same part numbers so irrelevant.(REAR driver maybe sustitute or superceded part #)
2. No fitment issues.
3. Unusual because front take more abuse. Change them only if loose.
4. No affect on alignment.
5. Easy to DIY, Floor Jack/Jack Stands and Basic hand tools. YES! ALWAYS TORQUE SUSPENSION FASTENERS TO RECOMMENDED OEM OR MANUFACTURE SPEC.
I would recommend buying aftermarket endlinks like SPL thier just a little more than OEM end links and are fully adjustable.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
