Need electritian!
Old Dec 4, 2011 | 01:31 PM
RubensG's Avatar
Need electritian!
Can any body vouch for one in the 818¿ I need someone to fix my headlights
Old Dec 5, 2011 | 01:26 AM
Majiks's Avatar
wow im in the 818, whats the problem with the headlights? and where in the 818 are you??? im in north hills, pretty much woodley and nordhoff
Old Dec 5, 2011 | 06:21 PM
RubensG's Avatar
im on nordhoff and Orion right off the 405. Key Fob works but isnt letting me open my doors by just hitting the black thing on the door and parking lights dont work but the high beams and fogs and turn signals and brakes lights work so im assuming its just wiring. and i dont know if its properly grounded cause it always shocks me when im trying 2 open my door.
Old Dec 6, 2011 | 01:19 AM
Majiks's Avatar
sounds like a grounding issue, first question have you checked all your fuses??
Old Dec 6, 2011 | 03:02 AM
RubensG's Avatar
no i havent ill check that ! today the keyfob worked fine for some odd reason... but then again it happened it stopped working and the ignition doesnt turn all the way into Lock. just turns till the one before that.
Old Dec 6, 2011 | 03:14 AM
Majiks's Avatar
well check your fuses, could be a loose fuse, but more likely a loose wire, and i honesty doubt its the battery in your fob
Old Dec 6, 2011 | 03:44 AM
RubensG's Avatar
but it should turn all the way regardless of battery issue you know? you know a good alignment shop around here? there's one on sepulveda n nordoff i might go to on weds. think im going to need a camber kit too.. any recommendations?
Old Dec 6, 2011 | 03:46 AM
Majiks's Avatar
well i have taken every car i have and my family has owned to steves, on nordhoff and woodley... they are fair as far as prices go, dont try to rip you off and do honest work, i actually used to work there a few years back. they did my alignment on my coupe about 5-6 months ago
Old Dec 6, 2011 | 09:50 AM
RubensG's Avatar
Thanks ill check them out today!
