A few mods made to the G during hibernation
Old Dec 28, 2011 | 10:58 PM
GEDsetG35's Avatar
looks nice.. are the tail light painted or film?
Old Dec 29, 2011 | 06:51 AM
YoTimesUp's Avatar
got to love Georgia weather... we had mid 60's- 70's like last week. MN TOOO cold hahaha [ATL area]
Old Dec 29, 2011 | 06:52 AM
YoTimesUp's Avatar
sweet ride btw!! forgot to tag that into my first post. lovin the photoshopped drop cant wait to see it on springs in the Spring
Old Dec 30, 2011 | 02:58 PM
ChildPlz85's Avatar
I painted the tail light myself with VHT Niteshade and was VERY pleased with how they turned out and I am very picky when it comes to my car. Another member here in MN had his tinted by a shop and his came out darker than he wanted so I figured I would do it myself so I could decide how dark I wanted. Here is a write up I did on the process:
So my mod mayem continues... This one I convinced myself I could tint my tail lights after smoking my clear corners with VHT Niteshade Tint. I only intended doing the clear corners, but they turned out well so I sacked up and did the tails.
I bought the spray can of tint at O'Reilly's for $11 and got a high gloss clear coat for $6. Also got 2000 grit wet-sandpaper for prepping the tail lights before spraying, and then will use it again on the clear coat to remove any imperfections. I also used rubbing alcohol on the lights before applying the spray tint.
Here are some pics throughout the process:
Wetsanding the tail light using 2000 grit sandpaper.
Rinsing off the light and then drying it. After it dried, I used rubbing alcohol to remove any grease or oils from my hands that got on the tail light. Now it was ready for spraying.
I sprayed a light first layer on the tail light, and then a very light second layer. I let it 'dry' for 5-10 min before applying the second coat.
After applying the two layers of spray tint, I let it dry for another 15 min and then applied the clear coat. I waited 5 min in between clear coats, and applied a total of three coats.
This is about an hour after the last clear coat was applied, I still need to take the 2000 grit sand paper to it and remove some of the imperfections on the tails. I will finish it off with polishing the lights. I am very happy with the result so far, and would suggest testing out the spray tint on something before your trying it on your actual tail lights .
So after letting the tint and clear coat cure for 24 hours, I wet sanded both tail lights with 2000 grit. Rinsed with soap and water, and then dried both. Here is a pic to show how scary the light looked before taking the compound and shinin' it all up
I then proceeded using a compound and rubbing out the light scratches, and I used a polish afterwards (on just a foam applicator) and 'buffed' out the rest of the scratches. There are still some scratches left that need to be removed (but are very difficult to see unless light is shining on the light at the right angle) once I get the buffer out later this winter after my tails are mounted on my car. I am VERY happy with how they turned out, and all it took was doing some research, being patient and making sure the prep work was all done correctly!
I would be happy to help anyone who wants to do this to their tail lights, because I would HATE for someone to try this for their first time on their stock tails and mess something up that can't be fixed.
I appreciate all the comments, I will be posting updated pics this spring after I get my KW V1 coilovers installed
Old Jan 3, 2012 | 01:58 AM
GEDsetG35's Avatar
love them!! im looking for some jdm tails and when i do hopefully you can help me out...
looks perfect not to dark or light...
Old Jan 3, 2012 | 02:47 AM
SAMzG35's Avatar
G35
Looks great!
keep up the good work
Old Jan 3, 2012 | 10:07 AM
R10T_x's Avatar
Looks good I kinda miss my tintes tails now ;(
Old Jan 8, 2012 | 08:23 AM
SupradonFaSho's Avatar
looking good bro!
Old Jan 10, 2012 | 12:06 AM
ChildPlz85's Avatar
Just got my Nismo CF Rear Diffuser in from Ionic Dynamics, very impressed with it! I will be installing later this week and post more pictures then...
Old Jan 27, 2012 | 11:51 PM
ChildPlz85's Avatar
Nismo CF diffuser installed... Fitment was perfect, thanks to Ionic Dynamics for the great product!
Old Jan 27, 2012 | 11:55 PM
IP_G35_MSR's Avatar
Beautiful!
Old Jan 28, 2012 | 12:02 AM
broke_as_ajoke's Avatar
looks nice bro
Old Jan 28, 2012 | 04:01 PM
High Octane's Avatar
Looks good. But personally I'm not a fan of tinted tails.
Old Jan 28, 2012 | 04:43 PM
Juelz905's Avatar
the cf diffuser looks great man. how much do they cost? i want the same, it looks great on our color.
Old Jan 28, 2012 | 05:41 PM
  #30
ChildPlz85's Avatar
Thanks guys appreciate the feedback! Juelz, I got the CF diffuser from Ionic Dynamics and it goes for $350 for CF and $220 for FG (unpainted).
