Worth buying this clutch kit?
Old Jan 21, 2012 | 10:10 PM
Dooki3butta's Avatar
http://www.ebay.com/itm/GRIPFORCE-HD...item2317153502.....
Pairing it with the stock dual mass flywheel. Any POSITIVE input is appreciated. Thanks
Old Jan 22, 2012 | 09:52 AM
UCIMAplaya2's Avatar
I have never tried that clutch nor heard of it so I cant comment either way. However if you are looking for a cheap clutch you should look at this one.
Amazon Amazon
Its the oem clutch. You don't want to buy a pos and have to install another one. Speaking of which are you planning on re-using your flywheels as is? Idk if you are aware that they don't usually machine them because its nearly impossible to do it properly.
Old Jan 22, 2012 | 11:16 AM
blackout2277's Avatar
I would spend another 40 or so bucks and get the exedy oem one. Don't cheap out over a few dollars when you might have to replace it soon again
jsimonk
Dec 22, 2023 03:49 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Jussaku
Aug 4, 2015 12:45 PM
vstypicals
Jul 20, 2015 10:55 PM
