help on wheel setup!
Old Feb 26, 2012 | 09:45 PM
alex526's Avatar
im looking at wheels that are 19x9.5+22 F and 19x11+25 R
As far as fitment goes, do you think it will be ok with just the fenders rolled?
im sure the front will be ok im just curious about the back.
Probably going with 235/35 front and 265/35 rear
Ill be dropped on bc racing coilovers
Old Feb 27, 2012 | 03:15 PM
alex526's Avatar
Cmon people I need to make an order lol
Old Feb 27, 2012 | 03:37 PM
VMRWheels's Avatar
Here are our V710s in 19x9.5 +22mm/19x11 +25mm with 245/275 tires.
The wheels and tires were pretty flush. Also, the fenders were rolled flat and the car is lowered on Stance coilovers.
Old Feb 27, 2012 | 03:48 PM
alex526's Avatar
That helps a lot Thank you
The wheels are also offerd in a 12 offset in the front and 15 in the back
Would this lead me to having to use negative camber and pull the fenders?
Old Feb 27, 2012 | 03:51 PM
VMRWheels's Avatar
I don't think pulling the fenders would be necessary to push them out 10mm more, but of course it all depends on your setup. If you're not planning on using much camber or something like that it may be necessary.
Old Feb 27, 2012 | 03:57 PM
alex526's Avatar
Alright that's what I figured just wanted to make sure , ill most likely end up buying wheels in the 22/25 offsets and add spacers if I want
Old Feb 27, 2012 | 04:00 PM
VMRWheels's Avatar
That would be what I would do personally. You can always lower the effective offset with spacers.
Old Feb 27, 2012 | 04:02 PM
jstudrawa's Avatar
Those rims are ****ing hot.
Old Feb 27, 2012 | 04:03 PM
alex526's Avatar
Haha thanks for the help man I apreciate it
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
Gomer
17 Inch
Aug 13, 2015 08:53 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
