Which FUSE is the interiot lights (dome/door) 03 g35 coupe
Old Mar 12, 2012 | 08:31 PM
tibasnatch's Avatar
searched but cant find exact one....dome lights and the lower door lights do not come on anymore..this happened when I installed speakers and the little light on bottom of door the 2 wires came out and im pretty sure its just a fuse as the bulb looks fine.
thanks
Old Mar 12, 2012 | 11:13 PM
crazynuts16's Avatar
Disconnect battery for 10 mins ^
Old Mar 13, 2012 | 12:08 AM
tibasnatch's Avatar
ok i will try that when i get up tomorrow...if that doesnt work? where is fuse?
thank you
Old Mar 13, 2012 | 12:12 AM
It happened to me when I was playing with the vanity light bulb. After panicing a lot, I disconnected the battery. Let it sit for 10 mins atleast, maybe 20 if you have time lol. I was being impatient so I barely waited 10 and it fixed it.
I checked all the fuses near the driver footwell and none of them were related to interior lights. You might check fuses behind the battery, get to them by removing the cowl cover.
But if you look at the pg section of the service manual, interior lights are controlled by the ipdm which is reset if you disconnect the battery.
Good luck!
Old Mar 13, 2012 | 11:23 PM
tibasnatch's Avatar
that worked thank you very much.
mike730
Jan 12, 2018 04:25 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
Jadenkid22
Jul 14, 2015 12:33 AM
