Car going into "safe mode"...
Old Mar 19, 2012 | 06:51 PM
jstudrawa's Avatar
A few months ago, I posted how my driver seat would randomly tilt or move backward without my using the switches, then when I tried to move it back, the switch was dead.
Well, now it's either worse or a new issue.
Driving home from work, the auto lights kicked in, and my dash flickered. A few miles later, the dash lit full up (like when you start the car) and manual mode turned into D.
So I drove home in 3rd gear, no shifting happened at all.
Pulled into the driveway, turned the car off and tried to restart. Nothing. No lights, nothing. **** wouldn't turn at all, no power getting anywhere. 30 minutes later tho, the car fired right up and all was good.
I have the Gordon Gee grounding kit, installed it a a year ago (15k miles). Going to go over that whole thing as well as take the seat out and check the switches.
Probably hit the dealer as well, for a full diagnostic unless anyone has any ideas.
Thanks guys.
Old Mar 19, 2012 | 06:54 PM
dofu's Avatar
20 Year Member
Check the battery and terminal connections.
Old Mar 19, 2012 | 07:28 PM
diablo_cc's Avatar
Old Mar 19, 2012 | 07:33 PM
jstudrawa's Avatar
Will check the battery and terminals.
No check engine light at all tho.
Old Mar 20, 2012 | 08:16 AM
jstudrawa's Avatar
Could the fact I have 275/35's on the rear and less than half tread on the front 225/40's have anything to do with VDC and shutting the car down?
Is the ECU resetting each time i can't restart the car?
Old Mar 20, 2012 | 12:55 PM
Teelux's Avatar
This can mean but one thing - You car is possessed, bro.
The power of Christ compells you!!!
Old Mar 20, 2012 | 04:17 PM
jstudrawa's Avatar
The 2007 with Bose doesn't have the radio/AC issue, right?
Old Mar 21, 2012 | 02:52 PM
JrSr2003's Avatar
Sounds like your car is freaking out.. this may be a dumb suggestion but i would check out your alternator. It may be going out... Your ecu will freak if it's not getting the voltage it needs..
Old Mar 21, 2012 | 03:12 PM
jstudrawa's Avatar
We did a battery test last night, 550 CCA, 12.65 car off, 14.73 car running.
No variations or spikes turning lights on, etc.
We tightened the terminals, negative was slightly loose. Hoping that I hit a bump and it altered the connection enough to cause the issue.
Hoping.
Thanks for the advice.
hdmark
Apr 29, 2019 04:31 PM
newg37
Jul 26, 2015 09:32 AM
si_driver
Interior
Jul 25, 2015 09:22 AM
Jadenkid22
Jul 14, 2015 12:33 AM
